Using 24.2.3.2 (x86_64) Had a problem with earlier version where Bookmarks would not hold alpha sort. Has gotten worse and now other Navigator categories like Headings. Tables, Hyperlinks etc. are opening and even if I select bookmarks to start with it does not hold after using once and jumps to some other section I don’t want. Used to be able to have only bookmarks open and it held an alpha sort – how can I get this back? I don’t know anything about coding or how to put in a patch/fix. I was hoping the recent update would have the issue corrected. Would appreciate any help.
tdf#104255
Suspect a fix for tdf#95378 - but it was changed in earlier versions (7.1, 7.3); you didn’t mention your previous versions.
Thanks for responding. I don’t have a record of my previous versions. I think the last one was the previous version in the spot where it describes the version as “more tested.” With that one I had the alpha sort problem but not the other issues that I am having with 24.2.3.2 (x86_64). I know I didn’t have these problems maybe a year ago. Should I just try to install an old version from the archive? Would I do that by selecting the link that says win (for Windows?).
