Calc: Problem with Freezing First Row
Freezing the first row in a spreadsheet tab (i.e., View > Freeze Cells > Freeze First Row) works fine – mostly. I always do this for every tab in a spreadsheet and even have it mandated in a Template. However, sometimes while working in a spreadsheet the freezing of the first row in all the tabs disappears, and I have to manually re-establish the setting. I have been using Calc for years (currently at 7.6.4.1) and have never discovered what causes this to happen.
Any help with this problem will be much appreciated.
Ned
Maybe related:
https://bugs.documentfoundation.org/show_bug.cgi?id=156434
Yes sir, it may well be. I quite regularly perform the actions mentioned in the bug report, but – to my embarrassment – I have never noticed the connection between these actions and the disappearance of the freeze. I shall pay careful attention over the next few days and endeavor to catalog my experiences. I’ll get back to you with a report of what I find.
Many thanks, Leroy, for bring this to my attention.
Ned
