Calc problems with Cut and Paste of decimal numbers
Since using LibreOffice 28.5 I have a couple of problems when using Calc.
First is an issue when using Tabs, each time I click on a Tab the “Rename Tag” box appears. I have to cancel this to be able to carry on. Is there a way of stopping this box appearing? I couldn’t find one in the Online Help.
Secondly, I have an issue when copying (or cutting) a cell set up as Currency. As soon as I Left Click the cell, the currency loses its two decimal places and appears as a prime number. If I go to the cell where I want to place the copy (or cut), the to be receiving cell address appears before the number in the copying cell. This means I have to manually delete the reference before I can complete the change.
I decided to go back to an old version of LibreOffice and the problems still haunt me but not as often. The version I reverted to was LibreOffice 25.2
Please paste here the information on Menu/Help/About LibreOffice (There is an icon to copy)
Looks like an issue with the mouse, please try to do the same with keyboard.
You could be right Miguel, I’ll try what you suggest.
Thanks for your help,
Danny Ross
I had a mouse that started double clicking on a single click, I had to replace the micro switches in it
Thanks for that, I’ll check it out.
Danny Ross
