I have a calc ods file with some dates that I want to sort. I have formatted all the cells in the format I want (MM/DD/YYYY) but Calc just keeps on displaying them in their original format e.g. 8 September 2025 and also it does not sort the dates correctly, One of the cells is formatted as I want (MM/DD/YYYY) - it had a tick mark in front of it which i removed. If i select any cell and right mouse to format cells, the dialog box picks MM/DD/YYYY correctly under the Format heading but the bottom right hand box under Locale prints the date as 8 September 2025 so it seems the date format is locked into a format I can’t use, I got these dates off a website by highlighting them and copy/paste into Calc. Any ideas out there?
Some of your dates are/were text, you can check if any others are by clicking View > Value highlighting (Ctrl+F8). Text will be black, Numbers and dates (which are just numbers with a specific format) will be blue, formulas will be green. Or we can assume that some are text, this page can help with that, How to convert number text to numeric data
Select the column of dates and click Format cells > Numbers and then in the Category pane, click Date.
- Select existing date format
D MMMM YYYYfrom the choices in the Format pane. OK.
Select all the dates in the column, then click Data > Text to Columns.
- In Separator options click Separated by and then select a character that is not in your column, e.g.
Tab - Click the column heading and then select in Column Type Date (DMY). OK
Now format the dates to your preferred format
Check for the faq I linked in this thread some minutes ago:
Thank you for your help here; your suggestion worked. I’ve been programming for > 40 years and I think it is misleading to allow me to format cells as Date and have the format icon show the cell value as Date but its not really a date as its really Text. I found this confusing and would likely have given up using Libreoffice Calc.
so you should not even complain about, but just fix it!
so you should aware of the fundamental difference between literal Text and interpreted Values.
see also
https://ask.libreoffice.org/t/change-numbers-formatted-as-text-into-dates/138718/4
Hmmm - not sure I’d want to get involved in a large codebase like LibreOffice and my expertise is in embedded C code controlling real world devices.
Thanks for pointers!
sorry my previous Comment seems was misleading, I’ tried to make it more clear!
