I have a link in a document and it is is blue and underlined. It prompts you to do a cntrl.click but it will not go off to the url.
Writer 4.4.3.2
Linux Caja 1,10,3
Writer 4.4.3.2
Linux Caja 1,10,3
Hi operacreamcake
The reason for that, normally, is because the Hyperlink is broken. LO/OO Hyperlinks are prone to such link breakage, and there is no simple method to find nor to bulk-fix those broken-links. Damn frustrating.
- Place the cursor in the middle of the hyperlink
menu):Edit→Hyperlink (Ctrl+K)Target in Document)In this particular case, the Hyperlink is NOT broken; therefore, Ctrl+Click works & jumps to the target of the link.
If the Hyperlink is broken it can be fixed by entering a valid link. That is your only current option. If you have 100 identical broken links, you will need to repeat for each of the other 99 broken Hyperlinks. Nice.
If this helps then please tick the answer (
…and/or show you like it with an uptick (∧)
