Conversion failed: could not save output document
There is issue with converting files to pdf. It occurs once out of 50-80 converted documents. Kindly advice.
LibreOffice 6.2.3.2
Jodconverter 2.2.2
PDF conversion via JodConverter failed with exit code: 1.
Error message: aug 09, 2023 9:30:20 AM com.artofsolving.jodconverter.openoffice.connection.AbstractOpenOfficeConnection connect
INFO: connected
aug 09, 2023 9:30:20 AM com.artofsolving.jodconverter.openoffice.connection.AbstractOpenOfficeConnection disposing
INFO: disconnected
Exception in thread “main” com.artofsolving.jodconverter.openoffice.connection.OpenOfficeException: conversion failed: could not save output document
            at com.artofsolving.jodconverter.openoffice.converter.OpenOfficeDocumentConverter.loadAndExport(OpenOfficeDocumentConverter.java:144)
            at com.artofsolving.jodconverter.openoffice.converter.OpenOfficeDocumentConverter.convertInternal(OpenOfficeDocumentConverter.java:120)
            at com.artofsolving.jodconverter.openoffice.converter.AbstractOpenOfficeDocumentConverter.convert(AbstractOpenOfficeDocumentConverter.java:104)
            at com.artofsolving.jodconverter.openoffice.converter.AbstractOpenOfficeDocumentConverter.convert(AbstractOpenOfficeDocumentConverter.java:74)
            at com.artofsolving.jodconverter.openoffice.converter.AbstractOpenOfficeDocumentConverter.convert(AbstractOpenOfficeDocumentConverter.java:70)
            at com.artofsolving.jodconverter.cli.ConvertDocument.convertOne(ConvertDocument.java:154)
            at com.artofsolving.jodconverter.cli.ConvertDocument.main(ConvertDocument.java:133)
Caused by: com.sun.star.io.IOException: SfxBaseModel::impl_store <file:///C:/Windows/TEMP/262596eb-aee5/vwghzjwj.pdf> failed: 0xc10(Error Area:Io Class:Write Code:16)
            at com.sun.star.lib.uno.environments.remote.Job.remoteUnoRequestRaisedException(Job.java:182)
            at com.sun.star.lib.uno.environments.remote.Job.execute(Job.java:148)
            at com.sun.star.lib.uno.environments.remote.JobQueue.enter(JobQueue.java:344)
            at com.sun.star.lib.uno.environments.remote.JobQueue.enter(JobQueue.java:313)
            at com.sun.star.lib.uno.environments.remote.JavaThreadPool.enter(JavaThreadPool.java:101)
            at com.sun.star.lib.uno.bridges.java_remote.java_remote_bridge.sendRequest(java_remote_bridge.java:652)
            at com.sun.star.lib.uno.bridges.java_remote.ProxyFactory$Handler.request(ProxyFactory.java:154)
            at com.sun.star.lib.uno.bridges.java_remote.ProxyFactory$Handler.invoke(ProxyFactory.java:136)
            at com.sun.proxy.$Proxy8.storeToURL(Unknown Source)
            at com.artofsolving.jodconverter.openoffice.converter.OpenOfficeDocumentConverter.storeDocument(OpenOfficeDocumentConverter.java:156)
            at com.artofsolving.jodconverter.openoffice.converter.OpenOfficeDocumentConverter.loadAndExport(OpenOfficeDocumentConverter.java:140)
            ... 6 more
any ideas?
