I want to create a column on a Libre Office Writer page which already has some contents (text). But when I create the column, text that is already on the page is automatically put into the column.
I want to make a blank column, to which I will later type in new contents. Think of a True/False test that you might have seen in school, where there is a column maybe 1 inch wide on the left side of the page, and the questions are already typed on the rest of the page. Then I want to open the document later and type in T or F beside each question, in the blank column.
Could you please either tell me how to make such a column, or direct me to the correct page of the wiki or user guide/manual. I did try to find it myself, but I could not.
Let’s see, my version is probably older… Oh look, I can just copy it:
Version: 24.2.7.2 (X86_64) / LibreOffice Community
Build ID: 420(Build:2)
CPU threads: 18; OS: Linux 6.8; UI render: default; VCL: gtk3
Ubuntu package version: 4:24.2.7-0ubuntu0.24.04.1
And this is on Linux. Below is the first part of the system info. You probably do not need all those details.
System:
Kernel: 6.8.0-51-generic arch: x86_64 bits: 64 compiler: gcc v: 13.3.0 clocksource: tsc
Desktop: Cinnamon v: 6.2.9 tk: GTK v: 3.24.41 wm: Muffin v: 6.2.0 vt: 7 dm: LightDM v: 1.30.0
Distro: Linux Mint 22 Wilma base: Ubuntu 24.04 noble
Machine:
Type: Laptop System: Dell product: Precision 3591 v: N/A serial: Chassis:
type: 10 serial:
Mobo: Dell model: 0P80KX v: A00 serial: part-nu: 0CBB
uuid: UEFI: Dell v: 1.6.1 date: 07/18/2024
Thank you very much!
brynn
