Custom style is inconsistent in different parts of the same document [character style applied]
OK so I’ve done a bit of fiddling and found a situation where I can see how it could be advantageous to have separate types of styles which is this: If you had a document that was mostly set to some Normal style but a few words were emphasized with an Emphasized style but then you wanted to change all the Normal paragraphs to some Normal2 style, that would overwrite the Emphasized styles and you would have to go re-select those words. In that case it makes more sense to me to think of styles as layers like in Photoshop (or like styles in CSS). In that approach there wouldn’t be special names for each style layer like paragraph or character style, just layers of styles where whichever layer is on top takes precedence.
Regardless, I just wish that the existence character styles was made more obvious when first using Writer. Since this feature is so different from most other writing programs most people are familiar with, I think it needs to be introduced to any new user. Maybe there should be a character styles drop-down in the main style toolbar right next to the paragraph styles drop-down too
You are right; you can see the interaction between paragraph ans character styles as layers, from bottom to top:
  • paragraph style
  • character style
  • direct formatting
Attributes in each layer hides the corresponding attributes in deeper layers.
My first copy of MS Word, in 1995 or thereabouts, came in a large box with a printed book explaining the basics of word processing. I read much of that, at least everything that I thought was relevant for me to know. I soon figured out that it was worth while to study all the tabs of the Tools - Options and Tools Autocorrect options dialog boxes in Word, which were pretty similar to those in Writer, by the way. “Read the manual” is one of the best pieces of advice that you can give for office software or stuff like Photoshop, CAD and the like. They have so hugely many features that jumping in without first orienting yourself is a sure way to failure.
