Customizing caption frame setting
Hi,
I know how to insert caption for image, but what I’m looking for is how to customize the frame.
For example, the default now for the frame will be 0 inch spacing on each side.
I want it to be 0.1 inch spacing at the bottom
I cannot find any way to customize the frame setting from the Styles and Formatting (F11)
Any ideas?
For a single frame you can:
  • Right click on the frame of the caption and select: Frame and make your settings
For more or all frames of the same document you can use Styles&Formatting window (F11):
  • Tab Frame Styles (third from left) > Frame > right click > Modify and make all your settings.
This gives you also the possibility to define several frame styles for the same document. In this case use New instead of Modify.
Styles&Formatting is a very powerful feature of LibO. I recommend to have a look at the free guides which you can download from http://www.libreoffice.org/get-help/documentation/
It does not work with auto-caption.
I have customized the Frame style, for example changing borders to dotted line.
When I insert a picture, which I have enabled an auto-caption for picture, the frame is still default, with no border around.
If I click the frame, and select from bar above the “Frame” style, then the frame will be applied.
It does not being applied automatically during auto-caption
