With the update clicking on the desktop icon does NOTHING. This has also happened before with several previous updates, and in each case I had delete it and to reinstall the most previous update. Another download a few days later has usually worked, but surely this could be corrected, for all time, before it occurs?
Can be difficult for an unknown OS…
Windows 11.
Das ist ein Problem von deinem Betriebssystem (kein LibreOffice-Problem!)
Das Symbol auf dem Deslktop ist immer mit der jeweiligen installierten LibreOffice Version verbunden.
Wenn du also updatest, verliert das Symbol die Verbindung zum Programm.
Translated via Deepl:
This is a problem with your operating system (not a LibreOffice problem!)
The icon on the desktop is always linked to the respective installed LibreOffice version.
So when you update, the icon loses the connection to the program.
and this doesn’t sound right. Only if folder or file is renamed a Shortcut looses its connection. If the executable file is at the same path after update, there should be no problem.
Also LO-Updater could recreate a shortcut.
You might like to look at General Installation Issues (Windows) - The Document Foundation Wiki
Probably, just go to Control Panel - Programs& Features, right click LibreOffice and select Repair should fix it.
Maybe anti virus is getting in the way?
I downloaded the update again intending to do what you suggest. It was only a few hours later, and this time the new icon worked.
As the later download worked when the earlier one had not, I presumed the problem had been addressed in the download. Exactly the same thing has now occurred with 3 or 4 updates.
I said:
It is something to do with your computer/installation. Possibly you have a Brother printer, or maybe some other cause. For me it works every time.
Version: 25.2.3.2 (X86_64) / LibreOffice Community
Build ID: bbb074479178df812d175f709636b368952c2ce3
CPU threads: 8; OS: Windows 11 X86_64 (10.0 build 26100); UI render: Skia/Raster; VCL: win
Locale: en-NZ (en_NZ); UI: en-GB
Calc: CL threaded
I just installed for the first time. After installation no start up icon on the desktop or in the Start Menu. I tried running repair but did not help. I went to C:/Program Files/ program and was able to launch the document program. I do not see any shortcuts in the Program Files. I can create the shortcuts manually but wondering why the installer and repair never did.
Maybe click Start Menu > Power > Restart (not Power Off as that defaults to hibernate) and then reinstall in a rebooted system.
That worked. The developers should build in a restart into the installation.
It isn’t LibreOffice that needs restarting; I can install without restarting. The issue is Windows, the default for Power Off is hibernate so Windows never gets to restart and all sorts of crud builds up in the system. Microsoft likes to pretend that Windows doesn’t need to be restarted regularly but it does.
You can change Windows to shut down when you power off.
- Go to
Control Panel\All Control Panel Items\Power Options\System Settingsand click the link Change settings that are currently unavailable. - In the Shut-down settings, untick Turn on fast start-up (recommended). Save Changes
