Digital signing in LibreOffice using PIV smart card (YubiKey) fails with “smart card cannot perform requested operation”
Hello everyone,
I am trying to digitally sign a LibreOffice document using a hardware security key (YubiKey-like device) via PIV smart card functionality on Windows, but I am unable to complete the signing process.
Here are the steps I followed:
  1. I created an X.509 certificate using the RSA 2048 algorithm.
  2. I imported the certificate and private key as a PFX into the security key (PIV slot).
  3. I imported the corresponding public certificate into the Windows Trusted Certificate Store.
  4. In LibreOffice, I opened a document and navigated to:
    File → Digital Signatures → Digital Signatures → Sign Document.
  5. A Windows Security dialog appears asking me to select the smart card.
At this point, I encounter the following issue:
  • After selecting the smart card, Windows shows the error:
    “The smart card cannot perform the requested operation or the operation requires a different smart card.”
  • If I press Cancel multiple times, the certificates eventually appear in LibreOffice.
  • However, even though the certificates are listed, LibreOffice does not allow me to sign the document using the smart card.
Questions:
  • Does LibreOffice officially support PIV smart card–based signing on Windows?
  • Are there specific certificate requirements (key usage, EKU, hash algorithm, provider type, etc.) needed for LibreOffice document signing?
  • Does LibreOffice rely on Windows CAPI / CNG, and are there known limitations with smart cards or hardware keys?
  • Is additional configuration (LibreOffice, Windows, or middleware) required to make this work?
Any guidance, documentation references, or confirmation of limitations would be greatly appreciated.
Thank you in advance.
maybe try Dependency tree for Bug 105605 - [META] Digital signatures bugs and enhancements
