I have just installed Libre Office 5.0.3. The Writer, at first glance, works well. And then I open a docx file and try the Insert-Document (another docx file), it says “error load, can’t read document” or something like that. The document is not corrupted or having anything wrong because I can open it directly from File-Open. How do I solve this?
Hi
Sorry for your problem. It is an already known Issue fixed with 5.0.4.
Thank you for reporting
Regards
