I am having an odd problem with Libre Office. I was using LibreOffice on an old 2015 MacBook Pro which had a sudden hard drive failure. I was unable to fix this. I purchased a new MacBook Air M3, and set it up using my latest Time Machine backup which unfortunately was from Dec 2023. Luckily, I store almost al my documents in icloud so when I logged in to iCloud, all the old Dec 2023 documents were updated, and any missing documents were downloaded. I checked that this happened when I logged into icloud. So far so good!
Anyhow, I noticed an issue when I opened my first document using Libre Office. When I opened it, it said there were two versions of the document but both had the same last modified date and time. I opened both to be safe, and both were exactly the same; however, I thought that some changes I thought I had made to it were missing but I wasn’t sure if my I was misremembering. I have now opened two further documents however and now I am sure that changes are missing.
How could this be happening? It appears that LibreOffice is somehow reverting to old versions of these documents, but how could this happen? Why doesn’t it just open the file that’s there? Why is libreoffice “seeing” two versions of s document when I only have one saved? Why are changes missing? Is there a way I can safely open these ods/odt files without losing the version in iCloud? Perhaps downloading OpenOffice? Sorry for all the questions!!
I am assuming now I’ve opened the “wrong” versions of these documents it’s overwritten the icloud docs and those changes are now lost?
I;ve copied below the version details from LibreOffice. It seems to say that I’m on MacOS 10.16?? But this isn’t correct (and not sure there is a 10.16?), I’m on Mac OS Sonoma 14.5 Old MBP was on Mojave 10.14.
Many thanks for any help! If you need further information do let me know
Sorry if the tag is wrong but none seemed to fit my issue. f there’s more appropriate one, let me know and I’ll change it. TY
Version: 7.1.8.1 / LibreOffice Community
Build ID: e1f30c802c3269a1d052614453f260e49458c82c
CPU threads: 8; OS: Mac OS X 10.16; UI render: default; VCL: osx
Locale: en-GB (en_GB.UTF-8); UI: en-US
It looks like any NEW documents (ie created since December 2023) which would have been missing from the TM backup, have been downloaded from iCloud, but any EXISTING documents that were on the TM backup, have not had any updates made since Dec 2023 downloaded - those updates are lost.
