Formatting calc sheets headers & Footers and Zero values
Linux Mint 18.1 Cinnamon 64 bit
Version: 5.1.6.2
Build ID: 1:5.1.6~rc2-0ubuntu1~xenial1
CPU Threads: 2; OS Version: Linux 4.4; UI Render: default;
Locale: en-GB (en_GB.UTF-8); Calc: group2
I have a Calc spreadsheet that has 7 different tabs. I want each sheet to have its own header and footer rather than them all being the same, as they are at present. I also want some of the sheets to display zero values while the other do not.
For two sheets to have different headers and footers those two sheets each need their own page style.
To hide zeroes, format the cells so that their number format code is 0;-0;. Read more about number format codes here.
Edit: Fixed format code. Thanks @erAck
That format code should include a minus sign in the second subformat, otherwise negative numbers are displayed without and look like positive numbers, so 0;-0;
