how do i freeze first column to print on each page
If you are working with Calc, choose menu Format
- Print Ranges
- Edit…
, and below Columns to Repeat type $A
(or click in the Shrink button
and click on column A).
Works in LibreOffice 6.3.6.2 (x86); OS: Windows 6.1.
Please, choose retag (below your question), delete common, type calc and press Enter twice. Thanks. The common tag is for all LibreOffice modules (Writer, Calc, Draw, etc.).
Add Answer is reserved for solutions.
Press edit below your question if you want to add more information; also can comment an answer.
Check the mark () to the left of the answer that solves your question.
