I made a document yesterday ans saved it multiple times. It’s in the recent documents thumbnails, but the program says it does not exist. HELP.
Thanks,
Jim
Always use your operating systems tools (which cannot be given, since you did not tell your operating system) to locate files and don’t rely on recent document list, which is worthless if you moved the file from one location to another one. Allmost all file managers (Caja, Dolphin, Nautilus, Windows Explorer - to name a few) I’m aware of support CTRL+F
to perform a file search.
For the 5th time I saved my document and the document disappears…important document… I will never use this thing again…
Please reply to LeroyG and Opaque to get further help.
Kind regards, Michel
