Help with a macro in LO Calc
The easiest way is to add to the end of the macro
  oWindow1.toFront
(tested for MS Windows).
In general, you need to take into account that after adding a second window, the document already has two controllers (and not one, as usual).
Yes, two controllers. But the toFront method doesn’t work (Ubuntu) because the windows don’t overlap. Focus does not move. Nothing happens.
So, here is the final code. @sokol92, thanks again.
REM  *****  BASIC  *****
Option Explicit
Sub ArrangeTwoWindowsVertical()
'''	Open two windows of the same document,
'''	displaying the first and second sheets in their windows (left and right).
'''	Calls: ActivateCell
'''	Remarks:
'''	 ⁈	• The height of each window was simply increased significantly
'''		(without calculation, by a factor of 2), and only then did they fill
'''		the entire height space. Bug, maybe. See: .Height * 2
'''		• Const: com.sun.star.awt.PosSize.POSSIZE = 15: Flags the x- and y-coordinate, width and height.
	On Local Error GoTo HandleErrors
	Dim oDoc, oDisp, oWin1, oWin2
	Dim oPosSize As New com.sun.star.awt.Rectangle  'maximized window possize
	Dim nWidthHalved&  'oWin1 width halved
	Dim nRemainder%  'remainder after division by 2
	oDoc = ThisComponent
	oDisp = createUnoService("com.sun.star.frame.DispatchHelper")
	' 1st Controller.
	With oDoc.CurrentController
		.ActiveSheet = oDoc.Sheets(0)
		Call ActivateCell(.ActiveSheet.getCellByPosition(0, 1))
		oWin1 = .Frame.ContainerWindow
		With oWin1
			.IsMaximized = True
			Wait 100: oPosSize = .PosSize
			nWidthHalved = oPosSize.Width \ 2: nRemainder = oPosSize.Width - nWidthHalved * 2
			.IsMaximized = False
		End With
		Wait 100
		With oPosSize
Rem			oWin1.setPosSize .X, .Y, nWidthHalved, .Height * 2, 15
			oWin1.setPosSize .X, .Y, nWidthHalved + nRemainder, .Height * 2, 15
		End With
		oDisp.executeDispatch(.frame, ".uno:NewWindow", "", 0, Array())
	End With
	' 2nd Controller
		oWin2 = .Frame.ContainerWindow
		oWin2.IsMaximized = False
		Wait 100
		With oPosSize
Rem			oWin2.setPosSize .X + nRemainder + nWidthHalved, .Y, nWidthHalved, .Height * 2, 15
			oWin2.setPosSize .X + nWidthHalved, .Y, nWidthHalved + nRemainder, .Height * 2, 15
		End With
		.ActiveSheet = oDoc.Sheets(1)
	End With
	oWin1.toFront
	Exit Sub
HandleErrors:
	Msgbox "Error " & Err & " in line " & Erl & ": " & Error _
	 , MB_ICONEXCLAMATION, "macro:ArrangeWindowsVertical"
Sub ActivateCell(oCell As Object)
	Dim oRanges As Object
	With ThisComponent
		.CurrentController.select(oCell)
		' NOTE: Same with .SheetCell or .SheetCellRange doesn’t work.
		oRanges = .createInstance("com.sun.star.sheet.SheetCellRanges")
		' Remove the highlight by passing the empty range collection.
		.CurrentController.select(oRanges)
	End With
Well, I’m a perfectionist, so I took into account one pixel lost from division (nRemainder).
My screen width is 1853 = 926 + 1 + 926. OS Linux makes so: 927 + 927, with an overlap of 1 pixel in the middle of the screen. However, the windows are glued (stuck together) there.
Try pressing the up/down arrows right after running the macro. In which window does the active cell change?
Right window
My left window becomes active in Ubuntu. You didn’t forget at the end of the macro:
oWindow1.toFront
Sorry. It works. Let’s stop there. Decision received. Thank you.
Thanks for the interesting topic!
