You ( @vh ) may study the attached example.
(Editing with respect to the comments by @vh
I am still confused about this somehow, but I lack the time to read every comment on every contribution here again.
If the solution you give factually is what you wanted, it was about the fractional part of the numbers in A3:A15. Since the internal handling of numbers is not decimal I wouldn’t talk of decimals in the case and surely not specialize on the point as the decimal separator.
In principle the appropriate expression returning the fractional part as you would see it displayed would be: MOD(ABS($A$3:$A$15);1). However, a comparison for equality with $B$3 would suffer from the effect of numerical extinction. Comparison for equality is always somehow problemtic in machine arithmetc.
Your formula will work better with this respect, but it will not return the result you may expect if A3:A15 can contain negative numbers.
Never trust in a formula just based on a few tests. There may be unexpected effects of signs, scale factors (order of magnitude) , and whatever in machine arithmetic because of its dyadic working and its limited precision.
To make your formula also work with negative numbers it should read:
{=SMALL(IF(IF($A$3:$A$15>=0;1;-1)*(TRUNC(ABS($A$3:$A$15))+$B$3)=$A$3:$A$15;ROW($A$3:$A$15);"");1)}.
To make it return all the matching rows at once yo migh use
{=IFERROR(SMALL(IF(IF($A$3:$A$15>=0;1;-1)*(TRUNC(ABS($A$3:$A$15))+$B$3)=$A$3:$A$15;ROW($A$3:$A$15);"");ROW($A$3:$A$15)-ROW($A$3)+1);"")}
(There are disadvantages of array output, however.)
On the other hand you once again stressed “I needed a solution WITHOUT having to convert anything to text.” I still assume a misunderstanding. A solution based on internal conversion (during formula evaluation) might even simplify a specific task without any effects concerning the usage of the sheet. The formula allowing for negative numbers I gave may not be very clear with respect to the intentions. Where interested in decimal digits whether left or right of the decimal separator, you are actually interested in text. The formula might better not veil this fact.
In addition working with helper columns (that may get hidden) will often allow for a better and much clearer structure in solutions. You should consider it. In this case the preparation of the relevant parts of numbers might be done in helper columns to simplify and make readable the formulae. Lack of a proper way of design-documentation is one of the most relevant disadvantages of spreadsheets. Helper columns can also help to relieve this.
