I was going to create a standalone script with the solution I came up with (using the accessibility api), but it doesn’t look like I’ll find the time. So what follows is the relevant parts of the project. Most of the time it works, but sometimes it stops and doesn’t press the Print button. Probably some waits are missing at some step.
This code let’s me print documents from vim. I’m not sure why I created a powershell wrapper, but whatever… The printing is performed in src\lib\print.py with the help of src\lib\accessibility.py.
vimrc:
let s:printer = 'Canon Whatever series'
" print one document, can take options (e.g. -NumberOfCopies n)
command! -nargs=1 PrintDoc1 execute 'r!powershell -ExecutionPolicy RemoteSigned -File src\bin\print.ps1 -Orientation landscape -PagesPerSheet 2 -FilePath ' . <q-args> . ' -Printer "' . s:printer . '"'
" print many documents, but take no options
command! -nargs=+ PrintDoc call s:PrintDoc(<q-args>)
function! s:PrintDoc(arg_s) abort
for arg in s:SplitArgString(a:arg_s)
execute 'r!powershell -ExecutionPolicy RemoteSigned -File src\bin\print.ps1 -Orientation landscape -PagesPerSheet 2 -FilePath ' . shellescape(arg) . ' -Printer "' . s:printer . '"'
endfor
endfunction
function! s:SplitArgString(s) abort
let r = split(a:s, '\v\s+(([^"]*"[^"]*")*[^"]*$)@=')
return map(r, {_, v -> substitute(v, '^"\(.*\)"$', '\1', '')})
endfunction
src\bin\print.ps1:
param(
[Parameter(Position = 0)]
$FilePath,
$Printer,
$NumberOfCopies,
$PagesPerSheet,
$Orientation,
$BothSides,
$Pages
$map = @{
Printer = '--printer'
NumberOfCopies = '--number-of-copies'
PagesPerSheet = '--pages-per-sheet'
Orientation = '--orientation'
BothSides = '--both-sides'
Pages = '--pages'
$argsList = @($FilePath)
foreach ($key in $PSBoundParameters.Keys) {
if ($key -ne 'FilePath') {
$argsList += $map[$key]
$argsList += $PSBoundParameters[$key]
src\bin\libre-python.cmd "src\bin\print.py" @argsList
src\bin\print.py:
import sys, argparse
import uno
from com.sun.star.table.BorderLineStyle import NONE as BORDER_LINE_STYLE_NONE
from com.sun.star.table.BorderLineStyle import SOLID as BORDER_LINE_STYLE_SOLID
sys.path.insert(0, r'src\lib')
import print as m_print
import libre.io
import libre.uno
parser = argparse.ArgumentParser()
parser.add_argument('--printer')
parser.add_argument('--number-of-copies', type=int)
parser.add_argument('--pages-per-sheet')
parser.add_argument('--orientation')
parser.add_argument('--both-sides')
parser.add_argument('--pages')
parser.add_argument('path')
args = parser.parse_args()
m_print.do(libre.uno.ctx(), libre.io.open(args.path),
**{k: v for k, v in vars(args).items() if k in [
'printer', 'number_of_copies', 'pages_per_sheet', 'orientation', 'both_sides', 'pages',
] and v})
src\lib\print.py:
from str import ucfirst
from accessibility import find_child, print_accessibility_tree, find_top_window, wait_for
from accessibility import AR_DIALOG, AR_PANEL, AR_PAGE_TAB_LIST, AR_PAGE_TAB, AR_CHECK_BOX, AR_LABEL, AR_COMBO_BOX, AR_RADIO_BUTTON, AR_PUSH_BUTTON
from accessibility import AR_TOOL_BAR
def do(ctx, doc, **kwargs):
# kwargs: printer, pages, number_of_copies, both_sides, orientation
press_print_toolbar_button(doc.CurrentController.Frame.ContainerWindow)
# dispatcher = ctx.ServiceManager.createInstance(
# 'com.sun.star.frame.DispatchHelper')
# dispatcher.executeDispatch(
# doc.CurrentController.Frame,
# '.uno:Print',
# 0,
d = wait_for(lambda: find_top_window(ctx, role=AR_DIALOG, name='Print'),
10, one=True)
general_pt = find_child(
wait_for(lambda: find_child(d, role=AR_PAGE_TAB_LIST, deep=True),
3, one=True),
role=AR_PAGE_TAB, name='General', one=True)
printer_cb = find_child(general_pt, role=AR_COMBO_BOX,
name='Printer', one=True, deep=True)
printer_cb.selectItem(kwargs['printer'], True)
if kwargs.get('pages'):
pages_rb = find_child(general_pt, role=AR_RADIO_BUTTON,
name='Pages:', one=True, deep=True)
pages_rb.State = True
pages_txt = find_child(general_pt, role=AR_RADIO_BUTTON,
name='Pages:', next=True, one=True, deep=True)
pages_txt.Text = kwargs['pages']
number_of_copies_sb = find_child(general_pt, role=AR_LABEL, name='Number of copies:',
# number_of_copies_sb.Value = kwargs.get('number_of_copies', 1) # 25.2.7.2: GUI changes but the result doesn't
for i in range(kwargs.get('number_of_copies', 1) - 1):
number_of_copies_sb.up()
collation_and_paper_sides_chb = find_child(general_pt, role=AR_CHECK_BOX, name='Collation and Paper Sides',
collation_and_paper_sides_chb.State = 1
paper_sides_cbb = find_child(general_pt, role=AR_COMBO_BOX, name='Paper sides:',
paper_sides_cbb.selectItem(
f'Print on both sides (duplex {kwargs.get("both_sides").replace("-", " ")})'
if kwargs.get('both_sides')
else 'Print on one side (simplex)',
True)
paper_size_cbb = find_child(general_pt, role=AR_COMBO_BOX, name='Paper size:',
paper_size_cbb.selectItem('A4 210mm x 297mm', True)
orientation_cbb = find_child(general_pt, role=AR_COMBO_BOX, name='Orientation:',
orientation_cbb.selectItem(
ucfirst(kwargs.get('orientation', 'portrait')),
True)
# print_accessibility_tree(d)
pages_per_sheet_chb = find_child(general_pt, role=AR_CHECK_BOX, name='Pages per Sheet',
pages_per_sheet_chb.State = 1
pages_per_sheet_cbb = find_child(general_pt, role=AR_COMBO_BOX, name='Pages per sheet:',
pages_per_sheet_cbb.selectItem(kwargs.get('pages_per_sheet', 1), True)
print_btn = find_child(d, role=AR_PUSH_BUTTON, name='Print',
print_btn.AccessibleContext.doAccessibleAction(0)
def press_print_toolbar_button(w):
panel = find_child(w, role=AR_PANEL, one=True,
pred=lambda n: find_child(n, role=AR_TOOL_BAR, name='Standard'))
toolbar = find_child(panel, role=AR_TOOL_BAR, name='Standard', one=True)
print_btn = find_child(toolbar, role=AR_PUSH_BUTTON, name='Print', one=True)
src\lib\accessibility.py:
import re, time, uno
from com.sun.star.accessibility.AccessibleRole import UNKNOWN as AR_UNKNOWN
from com.sun.star.accessibility.AccessibleRole import ALERT as AR_ALERT
from com.sun.star.accessibility.AccessibleRole import COLUMN_HEADER as AR_COLUMN_HEADER
from com.sun.star.accessibility.AccessibleRole import CANVAS as AR_CANVAS
from com.sun.star.accessibility.AccessibleRole import CHECK_BOX as AR_CHECK_BOX
from com.sun.star.accessibility.AccessibleRole import CHECK_MENU_ITEM as AR_CHECK_MENU_ITEM
from com.sun.star.accessibility.AccessibleRole import COLOR_CHOOSER as AR_COLOR_CHOOSER
from com.sun.star.accessibility.AccessibleRole import COMBO_BOX as AR_COMBO_BOX
from com.sun.star.accessibility.AccessibleRole import DATE_EDITOR as AR_DATE_EDITOR
from com.sun.star.accessibility.AccessibleRole import DESKTOP_ICON as AR_DESKTOP_ICON
from com.sun.star.accessibility.AccessibleRole import DESKTOP_PANE as AR_DESKTOP_PANE
from com.sun.star.accessibility.AccessibleRole import DIRECTORY_PANE as AR_DIRECTORY_PANE
from com.sun.star.accessibility.AccessibleRole import DIALOG as AR_DIALOG
from com.sun.star.accessibility.AccessibleRole import DOCUMENT as AR_DOCUMENT
from com.sun.star.accessibility.AccessibleRole import EMBEDDED_OBJECT as AR_EMBEDDED_OBJECT
from com.sun.star.accessibility.AccessibleRole import END_NOTE as AR_END_NOTE
from com.sun.star.accessibility.AccessibleRole import FILE_CHOOSER as AR_FILE_CHOOSER
from com.sun.star.accessibility.AccessibleRole import FILLER as AR_FILLER
from com.sun.star.accessibility.AccessibleRole import FONT_CHOOSER as AR_FONT_CHOOSER
from com.sun.star.accessibility.AccessibleRole import FOOTER as AR_FOOTER
from com.sun.star.accessibility.AccessibleRole import FOOTNOTE as AR_FOOTNOTE
from com.sun.star.accessibility.AccessibleRole import FRAME as AR_FRAME
from com.sun.star.accessibility.AccessibleRole import GLASS_PANE as AR_GLASS_PANE
from com.sun.star.accessibility.AccessibleRole import GRAPHIC as AR_GRAPHIC
from com.sun.star.accessibility.AccessibleRole import GROUP_BOX as AR_GROUP_BOX
from com.sun.star.accessibility.AccessibleRole import HEADER as AR_HEADER
from com.sun.star.accessibility.AccessibleRole import HEADING as AR_HEADING
from com.sun.star.accessibility.AccessibleRole import HYPER_LINK as AR_HYPER_LINK
from com.sun.star.accessibility.AccessibleRole import ICON as AR_ICON
from com.sun.star.accessibility.AccessibleRole import INTERNAL_FRAME as AR_INTERNAL_FRAME
from com.sun.star.accessibility.AccessibleRole import LABEL as AR_LABEL
from com.sun.star.accessibility.AccessibleRole import LAYERED_PANE as AR_LAYERED_PANE
from com.sun.star.accessibility.AccessibleRole import LIST as AR_LIST
from com.sun.star.accessibility.AccessibleRole import LIST_ITEM as AR_LIST_ITEM
from com.sun.star.accessibility.AccessibleRole import MENU as AR_MENU
from com.sun.star.accessibility.AccessibleRole import MENU_BAR as AR_MENU_BAR
from com.sun.star.accessibility.AccessibleRole import MENU_ITEM as AR_MENU_ITEM
from com.sun.star.accessibility.AccessibleRole import OPTION_PANE as AR_OPTION_PANE
from com.sun.star.accessibility.AccessibleRole import PAGE_TAB as AR_PAGE_TAB
from com.sun.star.accessibility.AccessibleRole import PAGE_TAB_LIST as AR_PAGE_TAB_LIST
from com.sun.star.accessibility.AccessibleRole import PANEL as AR_PANEL
from com.sun.star.accessibility.AccessibleRole import PARAGRAPH as AR_PARAGRAPH
from com.sun.star.accessibility.AccessibleRole import PASSWORD_TEXT as AR_PASSWORD_TEXT
from com.sun.star.accessibility.AccessibleRole import POPUP_MENU as AR_POPUP_MENU
from com.sun.star.accessibility.AccessibleRole import PUSH_BUTTON as AR_PUSH_BUTTON
from com.sun.star.accessibility.AccessibleRole import PROGRESS_BAR as AR_PROGRESS_BAR
from com.sun.star.accessibility.AccessibleRole import RADIO_BUTTON as AR_RADIO_BUTTON
from com.sun.star.accessibility.AccessibleRole import RADIO_MENU_ITEM as AR_RADIO_MENU_ITEM
from com.sun.star.accessibility.AccessibleRole import ROW_HEADER as AR_ROW_HEADER
from com.sun.star.accessibility.AccessibleRole import ROOT_PANE as AR_ROOT_PANE
from com.sun.star.accessibility.AccessibleRole import SCROLL_BAR as AR_SCROLL_BAR
from com.sun.star.accessibility.AccessibleRole import SCROLL_PANE as AR_SCROLL_PANE
from com.sun.star.accessibility.AccessibleRole import SHAPE as AR_SHAPE
from com.sun.star.accessibility.AccessibleRole import SEPARATOR as AR_SEPARATOR
from com.sun.star.accessibility.AccessibleRole import SLIDER as AR_SLIDER
from com.sun.star.accessibility.AccessibleRole import SPIN_BOX as AR_SPIN_BOX
from com.sun.star.accessibility.AccessibleRole import SPLIT_PANE as AR_SPLIT_PANE
from com.sun.star.accessibility.AccessibleRole import STATUS_BAR as AR_STATUS_BAR
from com.sun.star.accessibility.AccessibleRole import TABLE as AR_TABLE
from com.sun.star.accessibility.AccessibleRole import TABLE_CELL as AR_TABLE_CELL
from com.sun.star.accessibility.AccessibleRole import TEXT as AR_TEXT
from com.sun.star.accessibility.AccessibleRole import TEXT_FRAME as AR_TEXT_FRAME
from com.sun.star.accessibility.AccessibleRole import TOGGLE_BUTTON as AR_TOGGLE_BUTTON
from com.sun.star.accessibility.AccessibleRole import TOOL_BAR as AR_TOOL_BAR
from com.sun.star.accessibility.AccessibleRole import TOOL_TIP as AR_TOOL_TIP
from com.sun.star.accessibility.AccessibleRole import TREE as AR_TREE
from com.sun.star.accessibility.AccessibleRole import VIEW_PORT as AR_VIEW_PORT
from com.sun.star.accessibility.AccessibleRole import WINDOW as AR_WINDOW
from com.sun.star.accessibility.AccessibleRole import BUTTON_DROPDOWN as AR_BUTTON_DROPDOWN
from com.sun.star.accessibility.AccessibleRole import BUTTON_MENU as AR_BUTTON_MENU
from com.sun.star.accessibility.AccessibleRole import CAPTION as AR_CAPTION
from com.sun.star.accessibility.AccessibleRole import CHART as AR_CHART
from com.sun.star.accessibility.AccessibleRole import EDIT_BAR as AR_EDIT_BAR
from com.sun.star.accessibility.AccessibleRole import FORM as AR_FORM
from com.sun.star.accessibility.AccessibleRole import IMAGE_MAP as AR_IMAGE_MAP
from com.sun.star.accessibility.AccessibleRole import NOTE as AR_NOTE
from com.sun.star.accessibility.AccessibleRole import PAGE as AR_PAGE
from com.sun.star.accessibility.AccessibleRole import RULER as AR_RULER
from com.sun.star.accessibility.AccessibleRole import SECTION as AR_SECTION
from com.sun.star.accessibility.AccessibleRole import TREE_ITEM as AR_TREE_ITEM
from com.sun.star.accessibility.AccessibleRole import TREE_TABLE as AR_TREE_TABLE
from com.sun.star.accessibility.AccessibleRole import COMMENT as AR_COMMENT
from com.sun.star.accessibility.AccessibleRole import COMMENT_END as AR_COMMENT_END
from com.sun.star.accessibility.AccessibleRole import DOCUMENT_PRESENTATION as AR_DOCUMENT_PRESENTATION
from com.sun.star.accessibility.AccessibleRole import DOCUMENT_SPREADSHEET as AR_DOCUMENT_SPREADSHEET
from com.sun.star.accessibility.AccessibleRole import DOCUMENT_TEXT as AR_DOCUMENT_TEXT
from com.sun.star.accessibility.AccessibleRole import STATIC as AR_STATIC
from com.sun.star.accessibility.AccessibleRole import NOTIFICATION as AR_NOTIFICATION
from com.sun.star.accessibility.AccessibleRole import BLOCK_QUOTE as AR_BLOCK_QUOTE
accessible_role_map = {
AR_UNKNOWN: 'UNKNOWN',
AR_ALERT: 'ALERT',
AR_COLUMN_HEADER: 'COLUMN_HEADER',
AR_CANVAS: 'CANVAS',
AR_CHECK_BOX: 'CHECK_BOX',
AR_CHECK_MENU_ITEM: 'CHECK_MENU_ITEM',
AR_COLOR_CHOOSER: 'COLOR_CHOOSER',
AR_COMBO_BOX: 'COMBO_BOX',
AR_DATE_EDITOR: 'DATE_EDITOR',
AR_DESKTOP_ICON: 'DESKTOP_ICON',
AR_DESKTOP_PANE: 'DESKTOP_PANE',
AR_DIRECTORY_PANE: 'DIRECTORY_PANE',
AR_DIALOG: 'DIALOG',
AR_DOCUMENT: 'DOCUMENT',
AR_EMBEDDED_OBJECT: 'EMBEDDED_OBJECT',
AR_END_NOTE: 'END_NOTE',
AR_FILE_CHOOSER: 'FILE_CHOOSER',
AR_FILLER: 'FILLER',
AR_FONT_CHOOSER: 'FONT_CHOOSER',
AR_FOOTER: 'FOOTER',
AR_FOOTNOTE: 'FOOTNOTE',
AR_FRAME: 'FRAME',
AR_GLASS_PANE: 'GLASS_PANE',
AR_GRAPHIC: 'GRAPHIC',
AR_GROUP_BOX: 'GROUP_BOX',
AR_HEADER: 'HEADER',
AR_HEADING: 'HEADING',
AR_HYPER_LINK: 'HYPER_LINK',
AR_ICON: 'ICON',
AR_INTERNAL_FRAME: 'INTERNAL_FRAME',
AR_LABEL: 'LABEL',
AR_LAYERED_PANE: 'LAYERED_PANE',
AR_LIST: 'LIST',
AR_LIST_ITEM: 'LIST_ITEM',
AR_MENU: 'MENU',
AR_MENU_BAR: 'MENU_BAR',
AR_MENU_ITEM: 'MENU_ITEM',
AR_OPTION_PANE: 'OPTION_PANE',
AR_PAGE_TAB: 'PAGE_TAB',
AR_PAGE_TAB_LIST: 'PAGE_TAB_LIST',
AR_PANEL: 'PANEL',
AR_PARAGRAPH: 'PARAGRAPH',
AR_PASSWORD_TEXT: 'PASSWORD_TEXT',
AR_POPUP_MENU: 'POPUP_MENU',
AR_PUSH_BUTTON: 'PUSH_BUTTON',
AR_PROGRESS_BAR: 'PROGRESS_BAR',
AR_RADIO_BUTTON: 'RADIO_BUTTON',
AR_RADIO_MENU_ITEM: 'RADIO_MENU_ITEM',
AR_ROW_HEADER: 'ROW_HEADER',
AR_ROOT_PANE: 'ROOT_PANE',
AR_SCROLL_BAR: 'SCROLL_BAR',
AR_SCROLL_PANE: 'SCROLL_PANE',
AR_SHAPE: 'SHAPE',
AR_SEPARATOR: 'SEPARATOR',
AR_SLIDER: 'SLIDER',
AR_SPIN_BOX: 'SPIN_BOX',
AR_SPLIT_PANE: 'SPLIT_PANE',
AR_STATUS_BAR: 'STATUS_BAR',
AR_TABLE: 'TABLE',
AR_TABLE_CELL: 'TABLE_CELL',
AR_TEXT: 'TEXT',
AR_TEXT_FRAME: 'TEXT_FRAME',
AR_TOGGLE_BUTTON: 'TOGGLE_BUTTON',
AR_TOOL_BAR: 'TOOL_BAR',
AR_TOOL_TIP: 'TOOL_TIP',
AR_TREE: 'TREE',
AR_VIEW_PORT: 'VIEW_PORT',
AR_WINDOW: 'WINDOW',
AR_BUTTON_DROPDOWN: 'BUTTON_DROPDOWN',
AR_BUTTON_MENU: 'BUTTON_MENU',
AR_CAPTION: 'CAPTION',
AR_CHART: 'CHART',
AR_EDIT_BAR: 'EDIT_BAR',
AR_FORM: 'FORM',
AR_IMAGE_MAP: 'IMAGE_MAP',
AR_NOTE: 'NOTE',
AR_PAGE: 'PAGE',
AR_RULER: 'RULER',
AR_SECTION: 'SECTION',
AR_TREE_ITEM: 'TREE_ITEM',
AR_TREE_TABLE: 'TREE_TABLE',
AR_COMMENT: 'COMMENT',
AR_COMMENT_END: 'COMMENT_END',
AR_DOCUMENT_PRESENTATION: 'DOCUMENT_PRESENTATION',
AR_DOCUMENT_SPREADSHEET: 'DOCUMENT_SPREADSHEET',
AR_DOCUMENT_TEXT: 'DOCUMENT_TEXT',
AR_STATIC: 'STATIC',
AR_NOTIFICATION: 'NOTIFICATION',
AR_BLOCK_QUOTE: 'BLOCK_QUOTE',
def find_top_window(ctx, **kwargs):
toolkit = ctx.ServiceManager.createInstance('com.sun.star.awt.Toolkit')
ws = [toolkit.getTopWindow(i) for i in range(toolkit.TopWindowCount)]
return [w for w in ws if match_node(w, **kwargs)]
def find_child(n, **kwargs):
# kwargs: role, name, pred
# next, deep, one
r = []
cs = get_children(n)
for i, c in enumerate(cs):
if match_node(c, **{k: v for k, v in kwargs.items() if k in ['role', 'name', 'pred']}):
if kwargs.get('next'):
assert i < len(cs) - 1
r.append(cs[i + 1])
else:
r.append(c)
if kwargs.get('deep'):
r += find_child(c, **{k: v for k, v in kwargs.items() if k not in ['one', 'first']})
if kwargs.get('one'):
# print(r)
assert len(r) == 1
return r[0]
else: return r
def match_node(n, **kwargs):
return (not kwargs.get('role') or match_str_or_re(n.AccessibleContext.AccessibleRole, kwargs['role'])) \
and (not kwargs.get('name') or match_str_or_re(n.AccessibleContext.AccessibleName, kwargs['name'])) \
and (not kwargs.get('pred') or kwargs['pred'](n))
def match_str_or_re(actual, expected):
return re.search(expected, actual) if isinstance(expected, re.Pattern) else actual == expected
def get_children(n):
return [n.AccessibleContext.getAccessibleChild(i) for i in range(n.AccessibleContext.AccessibleChildCount)]
def wait_for(fn, timeout=10, **kwargs):
start = time.time()
while time.time() - start < timeout:
r = fn()
if r:
print(f'waited {time.time() - start:.1f} seconds')
assert len(r) == 1
return r[0]
return r
time.sleep(0.5)
raise RuntimeError(f'wait_for timed out after {timeout:.1f} seconds')
def print_accessibility_tree(n, depth=0):
ctx = n.AccessibleContext
describe_node(n, depth)
for i in range(ctx.AccessibleChildCount):
child = ctx.getAccessibleChild(i)
print_accessibility_tree(child, depth + 1)
def describe_node(n, depth=0):
print(' ' * depth + f'Role: ({role_to_string(ctx.AccessibleRole)})')
print(' ' * depth + f'Name: ({ctx.AccessibleName})')
print(' ' * depth + f'Description: ({ctx.AccessibleDescription})')
def role_to_string(role):
return accessible_role_map[role]
def print_node(n):
print([
role_to_string(n.AccessibleContext.AccessibleRole),
n.AccessibleContext.AccessibleDescription,
src\lib\libre\io.py:
from pathlib import Path
import uno
import libre.uno
import libre.docs
def open(path):
doc = get(path)
if doc: return doc
path = Path(path).resolve()
desktop = libre.uno.desktop()
return desktop.loadComponentFromURL(uno.systemPathToFileUrl(str(path)), "_blank", 0, ())
def get(path):
for doc in libre.docs.get():
if doc.URL.lower() == uno.systemPathToFileUrl(str(path)).lower():
return doc
src\lib\libre\docs.py:
import libre.uno
import libre.iter
def get():
r = []
for doc in libre.iter.mkgen(desktop.Components):
if doc.supportsService('com.sun.star.frame.StartModule'):
continue
r.append(doc)
return r
src\lib\libre\iter.py:
def mkgen(o):
enum = o.createEnumeration()
while enum.hasMoreElements():
yield enum.nextElement()
src\lib\libre\uno.py:
import uno
from util import in_libre
_ctx = None
def ctx():
global _ctx
if not _ctx:
_ctx = uno.getComponentContext()
if not in_libre():
resolver = _ctx.ServiceManager.createInstance('com.sun.star.bridge.UnoUrlResolver')
_ctx = resolver.resolve('uno:socket,host=localhost,port=2002;urp;StarOffice.ComponentContext')
return _ctx
_desktop = None
def desktop():
global _desktop
if not _desktop:
_desktop = ctx().ServiceManager.createInstance('com.sun.star.frame.Desktop')
return _desktop
_toolkit = None
def toolkit():
global _toolkit
if not _toolkit:
_toolkit = ctx().ServiceManager.createInstance('com.sun.star.awt.Toolkit')
return _toolkit
def chstruct(s, **props):
for k, v in props.items():
setattr(s, k, v)
return s
src\lib\util.py:
_in_libre = False
# scripts running from libreoffice should call in_libre(True)
# external scripts should not do this
def in_libre(v=None):
global _in_libre
if v is not None:
_in_libre = v
return _in_libre
src\lib\str.py:
def ucfirst(s):
return s[0].upper() + s[1:] if s else ''
