I want to email a document to be corrected and returned
PDF’s aren’t intended to be edited. You better solution is to share as ODF type and let the others in your group edit as needed. Save to PDF when your file is finalized.
saveing (aka. Exporting) as PDF
Send ing PDF via Email
[update] to make the pdf editable you have to check the odt embedding.
Hope that helps.
Have a nice day and let’s (continue to) “Be excellent to each other!”
Your right, I updated my answer with the hint to check the ODT embedding option. But … i am nur 100% sure if that is really what is requested. But it doent hurt.
