- The draw guide is not clear in that sense or perhaps I have found a bug.
- I have created a templateX without user styles and saved it in the LibreOffice templates directory.
- I have created a
document1based on that template and drawn a Rectangle2 (Default drawing style) - I have saved and closed the document and modified the Default drawing style in the templateX.
- When opening
document1it asks me for consent to update styles and I answer Yes - Rectangle2 in document should change based on the modified style in the template but it does not change.
Can someone explain the styles in draw?
Version: 26.2.4.2 (X86_64)
Build ID: 0229ac93fcf0d7cbc6376066c6f35021cef002dc
CPU threads: 8; OS: Windows 10 X86_64 (build 19045); UI render: Skia/Raster; VCL: win
Locale: es-ES (es_ES); UI: es-ES
