How insert text paragraph before table at top of body section in Writer
I created a table in the first paragraph of a normal Writer document, immediately under the header, which is blank.
I am unable to insert a line of text in front of the table in which I might type variable meta about the table.
Copy/cut - paste always produces a new page with the table sealed to that first line under the header.
Is there a work around short of creating a new table on a new page that contains
text paragraphs before the table?
Alt+Enter.
See LibreOffice Help on Shortcut Keys for LibreOffice Writer.
Thanks for the ref to Shortcuts; learned a helpful thing or two.
I should report that I searched for “inserting paragraph” after posting this request. An auto-fill suggestion “Inserting Text Before a Table at Top of Page” came up which solved my problem.
Thanks for the quick reply.
