how to change page orientation ? no help… Draw/Changing Page Orientation Landscape or Portrait
Hello @wiki,
- Select the menu
"Format : Page Properties...", - in the dialog that pops up, select the tab
"Page", - There in the field
"Orientation"you can select the radiobutton"Portrait"or"Landscape".
( at least in version 5.3.1.2 )
In 6.2.3.2, it is under Page → Properties and then select the tab Page.
Right click on the page canvas and select Page -> Properties Or From menu, select Page -> Properties.
In the Page tab, select your desired orientation - Landscape or Portrait.
Covered it here.
The LibO Writer Guide which can be downloaded from Writer Guides | LibreOffice Documentation - Your documentation for LibreOffice Chapter 6 Formatting Pages: Advanced, deals specifically with this formatting area. This includes issues with page numbering etc. For example, you often need to keep page header and footer information portrait and just rotate the contents of the page itself.
