How to display and print grid lines
I am learning, but I need to print a sample doc with grid lines
assuming you are talking about Calc:
To View
View -> [x] View Grid Lines
To Print
Format -> Page -> Tab: Sheet -> Category: Print -> Option: [x] Grid will show you the grid line on print
Hope that helps.
If the answer is correct or helped you to solve your problem, please click the check mark (:heavy_check_mark:) next to the answer.
Thank you! I wasn’t the original questioner. You provided the answer I needed. And the answer was correct and worked perfectly.
Click on print preview – in the opened window above your document select Format Page – select the Sheet tab– in the middle of the new window in the print section, select Grid.
