@Villeroy : I have had a look why so much people think there is a limit at 255 characters: The import wizard allows maximum length 255, will set back longer values but if you set Type → Automatic it will recognize there is more content needed. A little bit buggy…
Thanks RobertG,
Where does one find the Type–Automatic setting?
As stated before, the day one fails to learn something is probably the day one should stop all together!
Villeroy,
I am ignoring hours worth of stuff to post a very rough example of what jtm may be able to get a hold of and tune it in on their own. Give someone a fish to eat and they are fed for a day, teach them to fish and they will feed themselves. Did you expect me to come back with a finished product overnight? I don’t see where you have offered any useful help to jtm whatsoever!
A database with column types VARCHAR(255) NULL does not help anybody. Base wizards do not help anybody (except report wizard).
I would try to connect a Base document to the backend used by the frontend “S10 Presupuesto”. This would unveil all tables, columns, relations and indices and all the data within that structure within minutes.
unless they “protectected” access to this by password…
Googling a bit on the topic didn’t give much, but my top try would be MS-Sql-Server.
Edit: The assumption is confirmed when one combines "S10 Presupuesto” and “SQL-Server” for the google search.
https://www.udemy.com/course/presupuestos-de-obras-con-s10-presupuestos/?couponCode=BFCPSALE24 is a video that shows how to log in as a user named “sa” which I would translate as “system administrator”.
