Sorry for the late response, I have issues with the login process that I need to fix.
[There is a serious error to be supposed in cell J22 of your table.]
That is correct, thank you so much, I also corrected the values from T=34ºC and 35ºC if I remember correctly.
I probably didn’t understand the question fundamentally. Surely I didn’t understand the term “external value” in the context.
Sure, I didn’t explain myself correctly:
the command TREND allows to compare one value with a reference table of two columns (see LibreOffice and OpenOffice TREND function explanations for more info).
I’m looking for something similar that can be used with my table (with many columns) so it interpolates in both axis (rows and columns). The “External value” was a poor way of saying “a value that is not included in the table”.
But I’m going one step further, I want to operate the interpolated value to the “external” value.
In other words: I get data of MS at a certain temperature, my values are very precise (±0,01) in comparison with the data in the table (±5). The table is for correcting my data, so I can add/subtract certain values depending on the MS levels and the temperature.
I think one way of doing it could be comparing it with the 4 values (2 of MS + 2 of T) around of it instead of the whole row and the whole column since they are not quite linear by MS levels.
The table has classes of 1K width concerning the temperature, and of 5 units (whatever they are) concerning the MeasuredSucrose
I don’t understand what do you mean by “1K width”
The second (MS) resolution (in the values) is rather high anyway. Its maximum absolute step is 0.04
Concerning T the resolution is lower. The absolute step is 0.19 at maximum, nearly 5 times the other maximum.
Not sure exactly what do you mean by “resolution”.
Here is an updated version of the ODS file. I tried to correct the values using ={Original value}+SEARCHV(ROUND({Temperature};0);{Values of the table};1+MATCH(MROUND({Original value};5);{MS levels}))
but this basically adjust the values to their closest ones in terms of temperature and MS.
