How to set background color in Writer?
How do we set background color in Writer to be any color other than white color?
It seems we can set background color of text areas but not the entire page (including margins).
Thanks,
Narin
@narin1975: Feedback welcome… :wink:
Thanks everyone.
What I need is to export the document as PDF and when someone open this PDF file he should see the background of the whole page as one color other than the white color.
Have you seen my attached file “Page Style Background.pdf” (below: Background color including margins … EDIT 2012-10-25)?
yes. this works. thank you very much.
What I need is to export the document as PDF and when someone open this PDF file he should see the background of the whole page as one color other than the white color. - that should be included in the question, making it clear that this is not a matter of appearance (what we see when we write), but a matter of formatting(what is saved as PDF).
Styles and Formatting (F11) → Page Styles (4th icon from left)
Select "Default" → right click: "Modify..." or "New..."
Sample: New… → Page Style: Background
Page tab → Margins
Set all margins to zero
Background tab
Select the background color
Borders tab
Line arrangement: Set all four borders
Line → Color: (e.g.:slight_smile: the same as the background color
Spacing to contents: (e.g.:slight_smile: 20 mm
:ballot_box_with_check: Synchronize
The result
EDIT 2012-10-25
Sample
Hybrid PDF with embedded "Page Style Background.odt" (open with LibreOffice Writer, save as .odt)
That’s a workaround due to → Bug 33041 - Allow page background to cover the whole page, not only within page borders; see also → OOo Bug 9370 - Off-margin page background (2002-11-19).
Another workaround with a frame → Full A4 background image in Writer
fdo#33041 current status is NEW.
Beware that as of LibreOffice 7.0.1.2 the Background color should now be changed in the Area tab.
As an addition to the previous instructions of changing the document background colors using the Appearance editor, the selection of colors are only limited to a pre-defined list of colors. You can add your own custom color using Menu Tools → Options → LibreOffice → Colors.
Click “Add” to add a new color and provide a unique name, then click “Edit” to set the color to your liking, then click on “Modify” to save this color to the palette. Once this is done, your new color will be available in any of the color pick lists in the “Appearance” section.
This is a good candidate for a separate question “How do I add cutom colors to the palette?” :slight_smile:
Looking at a comment under the question it seems that the question is badly written, very different from what the title says. What the OP wants is not the appearance (color of what we see), but the formatting (what is saved as pdf)
I think he’s asking what I was curious about as well: how to set the actual background color of the Libre Office Application as a whole. If you’re looking at a page in Writer the default page background color is automatic/white, and the background of Writer is a 10% gray or so.
How would you change that 10% gray to be, say…40% gray?
Took a bit of Googling, but here’s the answer:
Go to Tools/Options/Libre Office/Appearance and change the “Application Background” option (third down on mine) to whatever color you want. This will change the application’s workspace background color only, not the menu background colors.
If you mean the "Appearance" (user interface):
Menu Tools → Options → LibreOffice → Appearance → Custom colors → General → Document background.
This did not work for me, ie. it did not change colour.
interesting way to do what Narin asked.
As long as it is only a change in color on screen, it works as proofen above. But if Narin considers to print the entire page (= paper) with a certain background color, I am afraid it will not work. Reason: Every printer has a printing area limit wich is a bit smaller than the paper.
I am now curious what Narin really wants to do.
Thanks everyone.
