Pop_OS! 22.10
LO Version: 7.5.0.3 (X86_64) / LibreOffice Community
Build ID: c21113d003cd3efa8c53188764377a8272d9d6de
CPU threads: 16; OS: Linux 6.1; UI render: default; VCL: gtk3
Locale: en-AU (en_AU.UTF-8); UI: en-GB
Flatpak
Calc: CL threaded
PROBLEM;
When clicking menu item, Help, for any LO module, LO will invoke the default browser and give this error…
Firefox can’t find the file at /home/ron/.local/share/flatpak/runtime/org.libreoffice.LibreOffice.Help/x86_64/stable/d7fbf3608042d8850ceb2b58afcbe178476857eb21a2b7279607662f9c6ea9f4/files/index.html?Target=swriter/.uno:HelpIndex&Language=en-GB&System=UNIX&Version=7.5.
Obviously, the relevant help file(s) must be placed into the relevant directory on the host drive.
But, I cannot find nor produce the file required. When I download the zip file from the LO site, and extract it, many files are created, but not one is the file required by the error message. The “readme” gives no explanations.
QUESTIONS:
After extracting the LO zip file, how to create the required help files?
Which files need to be placed into the directory noted above?
