When several spreadsheets are open, that contain multiple links between them and other sheets the system hangs every time even losing data i was in the middle of cutting a pasting
Cut and paste does not work, the system hangs ALL THE TIME.
Optimal Column widths no longer works like it did. What you see on the screen (100% zoom) is not what print preview or the printer shows and columns do not alter correctly one you use the Optimal Colums function.
I decided to reload the 24 version, but my computer did not like the look of it and had an odd file reference - www.tdf.jensgutermuth.de/libreoffice/stable/24.8.5/win/x86_64/LibreOffice_24.8.5_Win_x86-64.msi
as the download file.
I am competent, but not technical and have used this software since it was released by Sun Microsystems. Now I am stuck and faced with Excel because of the above
Someone please help in simple terms.
