I have a “Send Feedback” on my help pulldown, (it does not go to any of such! But. My feedback is. It would be nice if Calc had a tab in it that was a “Writer” tab. So all my info could be in one file.
The way it currently works is that all your info goes into one folder. Note that you can embed other LO objects in a different document, e.g. a spreadsheet in a writer document.
@MarkMcLean ,
please keep the headline as short as possible.
Otherwise I would edit it, but whether it is then correct?
You can include everything else in your description. Thank you.
