Impress - Mouse pointer as pen - continuous drawing problem
I was using Impress to give a presentation earlier today. At the beginning of the presentation, the “mouse pointer as pen” was working fine. But then it shifted into some kind of continuous drawing mode. Now, whenever I try using the pen during a presentation, it just draws continuously. If I take the pen away from the screen and move it to another section of the screen, the departure point and the new starting point will be joined by a straight line. It’s as if Impress is drawing continuously instead of stopping when my pen moves away from the screen. However, the problem does not seem to be the pen/tablet functionality as the pen works fine in other programs. I’ve also restarted LO, with no change in behavior.
Any suggestions?
I’m running LO 6.0.7.3 on Ubuntu 18.04 with a Wacom touchscreen laptop (Yoga X1)
Thanks!
Same problem with me.
Can anyone help?
