Insert a bibliography containing all entries, including not cited ones
I created a bibliography full of references. Most of them are not cited in my document. Nonetheless I would like to include those entries in the bibliography.
Is there a way to do that?
thanks in advance,
BenjD
short: No.
Workaround 1:
Create a new last page and insert all references there.
Workaround 2
If you use the internal bibliography database “biblio”, you can access it directly (Base) and create a report containing all data.
