I have found the Unicode char for you but cannot find and many, many fonts that contain the glyph for it:
⫫ (U+2AEB) DOUBLE UP TACK [Alias:- independence]
(from probability theory)
Extra:
I installed & checked Latin Modern Math (2014-09-05 19:59:00 - it was bound to have the glyph!) but it was empty as well (no it’s not, works fine - see below). It is not going to be an easy search.
Double Extra Cream:
Lupp states that his browser shows the glyph for DOUBLE UP TACK (⫫). Lord, but that is annoying, as my Debian system will not show it (neither Firefox 41.0.1 nor Chrome 26.0.1410.63) ( - not true, works fine).
Triple Extra Cream (licking my lips)
Regina stated that ‘Segoe UI Symbol’ contained the font & that was truly annoying as I was left as the only guy (apart from you) that could NOT see this wretched glyph. However, no longer, and it looks like the reason was an invalid font cache file (now fixed).
A 2nd font with the glyph for DOUBLE UP TACK (and many, many other symbols) is Quivira font (and rather nice, too). After putting Latin Modern Math in ~/.font I ran fc-cache -fv
& got this at the end:
:~$ fc-cache -fv
/usr/local/share/fonts: caching, new cache contents: 0 fonts, 0 dirs
/home/alexK/.fonts: caching, new cache contents: 1 fonts, 0 dirs
/var/cache/fontconfig: not cleaning unwritable cache directory
/home/alexK/.fontconfig: cleaning cache directory
/home/alexK/.fontconfig: invalid cache file: 89a7e9689afae9305e544233fdc49e84-le32d4.cache-3
fc-cache: succeeded
Everything seemed to work fine, so I ignored the error. However, after downloading Quivira (another free font) I ran fc-cache again. This time no error & both fonts work fine. In fact, all the other fonts that I’ve tried also have it. Whoops!
Here’s the final result:
:~$ fc-cache -fv
/home/alexK/.fonts: caching, new cache contents: 2 fonts, 0 dirs
fc-cache: succeeded
If this helps then please tick the answer (
…and/or show you like it with an uptick (∧)
