I’m using Windows 7 and have LibreOffice 7.3.4.2 x64.
Is there a way I can set ‘print duplex long side’ as default?
because now every time I need to manually set the setting on ‘print duplex long side’
In the settings of my printer, I have a similar setting, and I have placed that option on such a setting. And it works for all apps outside of LibreOffice. But every time, I want to print a document through LibreOffice I need to manually set it to ‘print duplex long side’ which is annoying because sometimes I forget it and waste, paper and ink.
