Issues using 26.2.0.3 with Horizon VDI
Installed 26.2.0.3 in Appvols using windows 11 desktops. The app opens successfully but as soon as I enter any text the app crashes out. If I revert back to 25.8.4 all applications work successfully. I have tried several fixes found online including SKIA, Hardware acceleration etc. The only way it works is if I uninstall 26 and revert back to the older version.
Skia is mandated on in 26.2, see https://wiki.documentfoundation.org/ReleaseNotes/26.2#Graphics
Open LibreOffice, click Tools > Options > LibreOffice > View and tick the box Force Skia software rendering. OK and allow LibreOffice to restart.
SKIA rendering was ticked but the box was greyed out, possibly due to it being mandatory. I will reinstall it later today and screen grab the settings.
You must tick the box Force Skia software rendering. It is there in your screenshot.
Even with that box ticked I still get the app crashing out when I attempt to enter data.
Please test with Menu>Help>Restart in Safe Mode.
I restarted in safe mode and as soon as I try to enter text it crashes out.
Try to update the graphics driver directly from the vendor.
This is a VDI environment. There is no graphics driver? The desktops are all cloned from a gold image and when you login Appvols are attached. We do have the latest version of VMWare tools installed, which controls graphics etc.
