LibreOffice Built-In Help
I keep getting a pop-up that says “The LibreOffice built-in help for current UI language (English (USA)) is not installed on your computer. You may either install it from our website or your system’s repositories, or read an online version.” Fine, but where do I go to do that? (I want to install it so I can check it even if I’m offline.)
click “Help for offline use”
The Help needs to be the same version as your LibreOffice version, check in Help > About LibreOffice. Also it needs the same bitness, that is, if you installed the 64-bit copy of LibreOffice then you need to download and install the 64 bit copy of Help.
The Guides to LibreOffice programs can be very helpful, download for free from English documentation | LibreOffice Documentation - LibreOffice User Guides
