I am a regular excel user, when I switch to libreoffice calc I found this simple usage are annoying, anybody knows how to do a proper VLOOKUP or is this a bug or something ?
let  say
you have  A…Z,[space],0…9 on Cell B4:B41 and its value  from 1…37 on C4:C41
and I make a simple VLOOKUP with formula something like this
=VLOOKUP(E4,$B$4:$C$41,2) for cell E5
and I copy the rest
from the screenshot as you can see from T to the rest you will have #N/A (i found this on windows) and on Linux the result would be the last values which is 37
so anybody can show me the proper way to use VLOOKUP in this
I have already try using Only Office etc the same problem exists but not with Excel or Google Sheet off course,
So I believe this might be a bug or something
regards
