Libreoffice calc: setting data bar with color per default instead of gradient
Hello, i find gradient is not very readable (personal taste) when applying conditional formatting + data bar. I am obliged, then to always change from gradient to color.
Is it possible to modify this setting so that i got it per default?
thanks
T
seems not.
