LibreOffice F1 help fails when offline‑help packages are removed
当用户完全卸载LibreOffice全部离线帮助组件包之后,按下F1帮助快捷键,软件依旧强制调用本地file://协议的离线帮助文件路径,不会自动降级跳转官方在线帮助网页。旧版本LibreOffice图形界面中自带的「优先使用在线帮助」配置开关选项已经被彻底移除,普通用户不再拥有任何图形界面配置入口,无法手动切换帮助模式。
在Deepin、UOS等国产Linux发行版环境,以及Snap、Flatpak容器化安装的LibreOffice版本下,系统浏览器具备严格的安全沙箱拦截策略,会直接拒绝外部程序唤起file‑URI本地文件链接,触发找不到文件的报错弹窗,造成F1帮助快捷键功能完全失效,用户无法查阅任何帮助资料。
该问题对不安装庞大离线帮助包的轻量化部署场景影响尤为严重,很多Linux发行版默认不附带离线帮助组件,开箱即遇到F1帮助无法使用的情况。
期望修复方案:
  1. LibreOffice启动或按下F1的时候增加离线帮助资源检测逻辑,检测本地离线帮助文件、帮助组件不存在时,F1快捷键应当自动跳转官方在线帮助网页,而不是继续调用不存在的本地file路径。
  2. 在选项设置界面恢复图形化配置选项,提供可供用户手动切换的开关,允许使用者根据自身环境自由选择优先使用本地离线帮助,或者优先使用网络在线帮助模式。
  3. 容器打包版本(Snap/Flatpak)应当适配该逻辑,避免容器沙箱文件访问限制造成帮助功能不可用。
The LibreOffice Math formula editor is primarily designed and optimized for mathematical formula composition, and it lacks complete native support for chemistry‑related writing and teaching workflows. Multiple notable usability issues exist for chemistry users.
First, all chemical element symbols are rendered in italic font by default. This contradicts established international academic standards for chemical notation, where element symbols should use upright roman type. Users have to insert the nitalic{} markup command manually for every single chemical element symbol one‑by‑one to get correct upright text. There is no global toggle or one‑click setting inside the Math module to disable automatic italicization specifically for chemical formulas. Repetitively adding markup for each element creates heavy redundant work for users writing long chemical equations.
Second, the built‑in symbol panel is missing many essential chemistry‑specific graphical symbols. This includes the reversible equilibrium arrow for chemical reactions, precipitation symbol, gas evolution symbol, as well as left superscript and left subscript glyphs required for isotope notation. None of these frequently‑used chemistry items are available as clickable UI buttons. Users can only produce these symbols by memorizing obscure markup syntax and typing code manually, raising the learning barrier significantly for students and teachers.
Third, LibreOffice Math does not ship with an official built‑in template library for common chemical scenarios. Templates are absent for ionic equations, redox reaction equations, isotope marking formulas and other widely‑used chemistry formula types. Ordinary users cannot leverage ready‑to‑use one‑click templates and must memorize a large set of special syntax rules. This results in low writing efficiency and poor user experience for chemistry‑oriented document creation.
Expected improvements:
Add a dedicated chemistry‑oriented working mode together with an independent chemistry‑specific toolbar within the Math module. When this chemistry mode is activated, all chemical element symbols should display as upright roman font by default to comply with international academic standards. Add one‑click graphical UI buttons for all frequently‑used chemical symbols and isotope‑related notation elements. Deliver a comprehensive official template library covering chemistry formula use‑cases from middle‑school level up to university‑level content, including standard chemical reaction equations, ionic equations and isotope formulas.
