LibreOffice Impress 7.3.5.2 will not hold text box position and size
LibreOffice Impress 7.3.5.2 will not hold text box position and size even though Protect Position and Size boxes are ticked. Moreover, dimensions of text box go over bottom of slide even dimensions and x,y positions are dialog box are correct. OS = Unity Ubuntu 22.04. File saved as ODP.
Please, basically you have to specify the operating system.
Furthermore, specify the file type in which you saved.
To help you better, it is appropriate to upload a sample file with the problem here.
Edit your initial question, to do it.
Thanks.
Do not use comments for this.
