Libreoffice not using macOS system font for GUI and other problems
Hello.
I’m currently using the latest version of Libreoffce Fresh. On macOS the app uses Liberation Sans for its interface (or at least it looks like it to me) but doesn’t really use the default macOS System font used by any other app on mac, including open source rebuilds of other software.
Is there any way to enable the default system font? Liberation sans is in many cases way too big compared with the usual font.
Also I recently had installed a custom font (URW Franklin Gothic) and Libreoffice used that instead Liberation Sans. I had to uninstall that font completely in order to get a readable interface. Especially this one is a pretty important bug in my opinion, and one probably connected to Libreoffice’s inability to use the proper system font.
Does anyone have some ideas about how to fix this problem? Thanks in advance.
Sounds like a MacOS system setting, try this page Customise your Mac with System Settings - Apple Support (NZ)
No, this question is about the font used for the user interface in LibreOffce. I’m also wondering if the app could get the option to use the system font when running on macOS rather than the custom one? Would this take a theme extension?
If the system font is not being used in the LibreOffice interface then it is either a setting in Mac or a corrupt font cache in Mac.
https://discussions.apple.com/thread/253684673?sortBy=rank
