I am running Linux Mint 18 and I installed libreoffice7.2. It not only will not start, but now the previously installed libreoffice7.1 and 7.0 will not start. When I run libreoffice7.2 in a terminal, I get:
(soffice:3017): Gtk-WARNING **: Theme parsing error: :1:354: ‘min-height’ is not a valid property name
(soffice:3017): Gtk-WARNING **: Theme parsing error: :1:368: ‘min-width’ is not a valid property name
(soffice:3017): Gtk-WARNING **: Theme parsing error: :1:696: ‘min-height’ is not a valid property name
(soffice:3017): Gtk-WARNING **: Theme parsing error: :1:710: ‘min-width’ is not a valid property name
/opt/libreoffice7.2/program/soffice.bin: symbol lookup error: /opt/libreoffice7.2/program/libvclplug_gtk3lo.so: undefined symbol: gtk_widget_path_iter_set_object_name
I get similar errors from 7.1, and an error from 7.0 indicating a folder could not be created. I tried
export SAL_USE_VCLPLUGIN=gen
per a previous response to a similar question here, but then I get a different error:
terminate called after throwing an instance of ‘com::sun:
:lang::WrappedTargetRuntimeException’
Unspecified Application Error
I tried re-installing gtk-3 and rebooting, but that didn’t help.
Any ideas?
