Trying to install 6.0.4.2 on Linux Mint 18.3 with GB help file. (I prefer local help for when I’m not online - yes there are a few of us that live disconnected at times).
Don’t want to use Flatpak so please, no suggestions in this direction.
I’ve poked and prodded a bit but I’ve reached the point where I don’t know if I missed doing something or whether the installation dependencies are actually wrong. Any pointers gratefully received to get the help file installed properly.
Here’s what I did:
- Uninstalled the distro version of LO and purged config files.
- Downloaded 6.0.4.2 64 bit
- Installed using dpkg
The applications work fine, but the local help shows as not installed within the applications.
However when I go to install the 6.0-en-gb help file I get
rick@tardismint ~/Downloads/LibreOffice_6.0.4.2_Linux_x86-64_deb_helppack_en-GB/DEBS $ sudo dpkg -i *.deb
(Reading database ... 550476 files and directories currently installed.) Preparing to unpack libobasis6.0-en-gb-help_6.0.4.2-2_amd64.deb ... Unpacking libobasis6.0-en-gb-help (6.0.4.2-2) over (6.0.4.2-2) ... dpkg: dependency problems prevent configuration of libobasis6.0-en-gb-help: libobasis6.0-en-gb-help depends on libobasis6.0-en-gb (>= 6.0.4.2); however: Package libobasis6.0-en-gb is not installed. libobasis6.0-en-gb-help depends on libobasis6.0-en-gb (<= 6.0.4.2-2); however: Package libobasis6.0-en-gb is not installed. dpkg: error processing package libobasis6.0-en-gb-help (--install): dependency problems - leaving unconfigured Errors were encountered while processing: libobasis6.0-en-gb-helpIf I try to fix using apt-get
The following packages will be REMOVED libobasis6.0-en-gb-help 0 to upgrade, 0 to newly install, 1 to remove and 26 not to upgrade. 1 not fully installed or removed. After this operation, 25.7 MB disk space will be freed. Do you want to continue? [Y/n]…and while trying to remove some other stuff using autoremove showed:
DEBS $ sudo apt-get autoremove Reading package lists... Done Building dependency tree Reading state information... Done You might want to run ‘apt-get -f install’ to correct these. The following packages have unmet dependencies. libobasis6.0-en-gb-help : Depends: libobasis6.0-en-gb (>= 6.0.4.2) but it is not installable Depends: libobasis6.0-en-gb (<= 6.0.4.2-2) but it is not installable E: Unmet dependencies. Try using -f.Which squares with the content of the control file in the help .deb
