Why is the option Modify grayed for “Insert non-breaking space shortcut”?
I’d like to change it for something else than shift-command-space. That’s on mac with LO 7.2. Or is there some extension for it?
The keyboard shortcuts definitions are configured by Tools
>Customize
. This menu item may be located elsewhere under MacOS because Tools
>Options
is relocated to Preferences
Button Modify
is grayed out until you select a shortcut. If it remains disabled after highlighting your target shortcut, it may be that the OS intercepts this combination and never lets you change it in an application.
