Need help with corrupted file: SAXException: [word/document.xml line 2]: Opening and ending tag mismatch: sdtContent line 2 and del
Please try again.
It works! Thank you so much for your help, Mike. Literally saving me hours of work. Can’t thank you enough! Have a wonderful day. :slight_smile:
You are the man @mikekaganski!
I love seeing you helping so many people here.
Thanks for all of your great work!
Hi @mikekaganski,
is it possible that you help me with recovering a file?
the error says:
Dateiformatfehler an Position (Document error on position)
SAXParseException: '[word/document.xml line 2]: Opening and ending tag mismatch: rPr line 2 and ins
', Stream ‘word/document.xml’, Line 2, Column 114998(Zeile,Spalte) entdeckt (found).
the problem occured, when i closed the window by pressing the “X” and instead of asking me if i want to save before closing no message appeared. it just closed.
the file is confidential. so if you can help me, then i would like to send it to you in private.
thanks
David
I’m having a similar problem. The message error is this one: SAXException: [word/document.xml line 2]: Opening and ending tag mismatch: sdtContent line 2 and hyperlink
Can anyone help? I’m desperate.
Dear Mike Ganski,
Thank you very much for your super fast help! You saved me. Thanks a lot!
Pavlina
čt 12. 9. 2024 v 11:26 odesílatel Mike Kaganski via Ask LibreOffice <noreply@ask.libreoffice.org> napsal:
@mikekaganski Hello ! You seem to have a miracle solution.
Could you please fix this flie ?
Thanks a lot !
File sent.
thank you very much! you are a genius!
@mikekaganski Hello. I have read that from now on, I should save in .odt format, and have just upgraded to the latest version of LibreOffice.
But, would it be possible to rescue the attached file for me, which is giving the same error as mentioned above? It was 21 pages and now opens as 3 pages, and was a lot of work lost. Thank you SO much!
`type or paste code here`
https://drive.google.com/uc?export=download&id=1ht6wgvJk8RstTrvoGPSrCOSy0sucRCj7
Wow, I am so grateful! I wish I could send chocolate cookies in my reply. :pray:
