I have problem with the page numbering of my document. I have 8 pages of paper. I just realized that after page 4, it starts again with page one. I have no idea what’s going on. Can somebody help me to fix this. Thanks
Please edit your question to indicate: operating system, LO version, file format (ODT, DOC, DOCX) and whether page styles or section breaks have been used (and where). Thanks.
Please try all solutions given in similar questions (e.g. tagged ‘page-numbering’) and then describe how your problem is different. Thanks.
It is a difficult to guess what you did, thus I changed a page in the middle of a document to start with 1.
You can read about this in the help file searching for “page number”
I would check the setting on page 5, which is the page which starts with page number 1 again.
In details:
- Click into the first paragraph of this page
- Format > paragraph > tab Text flow
I assume that you have the check marks and the page number 1 as in below image.
If so, remove the 2 check marks indicated with red arrows and all should be fine.
They are unchecked and page 4 still goes to 0.
