Please help with page numbers
When I try to add page number to my footer - Format - fields - Page Number - it gives me not number, but on all pages I have just sign “Page Number”.
Could you help me how to change sign “Page Number” to real numbers?
Thank you for any help,
Paul.
Which version of LO are you running?
In my 5.1.2.2 the page number is under Insert > Page Number
In V4 I remember it was under Insert > Fields > Page Number (not under Format).
If you inserted from here and still see “Page Number” then you have to go under View Field Names (I believe Ctrl+F9)
Best of luck.
If this answers your question please remember to mark it so for the benefit of all the community. Thanks
Related help page.
Greaat!! Thank you so much… my version is 4.2.8.2. I did - Insert - fields - page number. Then I had not numbers, but sign “page number” - then i pressed ctrl+F9 and number showed up :slight_smile: Thank you so much!!
Great!
I also made a mistake even in v5 it’s in the same menu, I misread the first entry :slight_smile:
