Hi!
I’ve got a problem, in my LibreOffice Calc file…
When I select a cell, I got a font size, here 11 pt. And when I select the text in it, to modify it, the size changes, here 19,4pt !
How comes?
Capture
Thank you very much,
Antoine
—edited by @Hrbrgr
Version: 7.6.0.3 (X86_64) / LibreOffice Community
Build ID: 69edd8b8ebc41d00b4de3915dc82f8f0fc3b6265
CPU threads: 4; OS: Windows 10.0 Build 19045; UI render: Skia/Raster; VCL: win
Locale: fr-FR (fr_FR); UI: fr-FR
Calc: CL threaded
Capture2
here is the second image.
Which operating system and which LibreOffice version are you using?
Use menu Help > About LibreOffice the button Version Information to save the data to the clipboard. Paste the data into your initial question.
And in which file format do you save?
Hi, thanks for the answer.
Calc: CL threaded
It is an ods file. But not quite sure if it didn’t come from a Excel file first…
Thanks for dates.
Can you please upload a spreadsheet here that has the problem so someone can examine it? Thanks.
Here it is : Send
Actually, the solution was to select all the cells in the same time, and change the size.
It didn’t work cell by cell…
However… :slight_smile:
There is a difference between LO 7.5.5.2 (font size 11) and LO 7.6.0.3 (font size labelled 19.4 pt but appearance 11 pt).
I don’t know if it is a corrupted spreadsheet or a bug. Best if you report a bug, How to Report Bugs in LibreOffice - The Document Foundation Wiki
The issue is still there without embedded fonts, even Default cell format does the same. Here is a modified sample with 4.2 MB of fonts removed.
Suivi formation - WithoutEmbeddedFonts.ods (17.2 KB)
It’s a bug, that I could’t find just now.
EDIT: Maybe it was a question that was deleted.
EDIT 2: Not a question, but a bug report. I get an e-mail, so here is the number: tdf#156209
There is a patch that “will be available in 7.6.1”.
Done here : 157048 – CALC TEXT FORMATING Font size different
