I’m a newbie in Ubuntu and I’m using Ubuntu 13.10. This week I’ve removed libreoffice
packages (using synaptic) from my system because I understand that an upgrade of libreoffice
would fix a bug which won’t let me use keyboard shortcuts while in foreign layout.
After removing all my packages containing term ‘libreoffice’ I’ve downloaded the last version of libreoffice
4.1.4, (from Libreoffice site) unzipped it with archive manager and then typed the command sudo dpkg -i *.deb
in DEB folder.
the installations seems to stop in the middle without putting any icons on my unity launcher
I typed in terminal “libreoffice4.1” but it did not execute. this msg error appeared:
The application cannot be started.
[context=“shared”] caught unexpected com.sun.star.ucb.InteractiveAugmentedIOException: > a folder could not be created
(EDIT: I think Ive solved this problem deleting libreoffice directories in .config directory:
using sudo rm -r ~/.config/libreoffice*
it executes now but the initial bug of shortcut keys still persists)
Below are the results of the output after entering sudo dpkg -i *.deb
appreciate your help
Selecting previously unselected package libobasis4.1-base.
(Reading database ... 1086109 files and directories currently installed.)
Unpacking libobasis4.1-base (from libobasis4.1-base_4.1.4.2-2_i386.deb) ...
Selecting previously unselected package libobasis4.1-calc.
Unpacking libobasis4.1-calc (from libobasis4.1-calc_4.1.4.2-2_i386.deb) ...
Selecting previously unselected package libobasis4.1-core01.
Unpacking libobasis4.1-core01 (from libobasis4.1-core01_4.1.4.2-2_i386.deb) ...
Selecting previously unselected package libobasis4.1-core02.
Unpacking libobasis4.1-core02 (from libobasis4.1-core02_4.1.4.2-2_i386.deb) ...
Selecting previously unselected package libobasis4.1-core03.
Unpacking libobasis4.1-core03 (from libobasis4.1-core03_4.1.4.2-2_i386.deb) ...
Selecting previously unselected package libobasis4.1-core04.
Unpacking libobasis4.1-core04 (from libobasis4.1-core04_4.1.4.2-2_i386.deb) ...
Selecting previously unselected package libobasis4.1-core05.
Unpacking libobasis4.1-core05 (from libobasis4.1-core05_4.1.4.2-2_i386.deb) ...
Selecting previously unselected package libobasis4.1-core06.
Unpacking libobasis4.1-core06 (from libobasis4.1-core06_4.1.4.2-2_i386.deb) ...
Selecting previously unselected package libobasis4.1-core07.
Unpacking libobasis4.1-core07 (from libobasis4.1-core07_4.1.4.2-2_i386.deb) ...
Selecting previously unselected package libobasis4.1-draw.
Unpacking libobasis4.1-draw (from libobasis4.1-draw_4.1.4.2-2_i386.deb) ...
Selecting previously unselected package libobasis4.1-en-us.
Unpacking libobasis4.1-en-us (from libobasis4.1-en-us_4.1.4.2-2_i386.deb) ...
Selecting previously unselected package libobasis4.1-en-us-base.
Unpacking libobasis4.1-en-us-base (from libobasis4.1-en-us-base_4.1.4.2-2_i386.deb) ...
Selecting previously unselected package libobasis4.1-en-us-calc.
Unpacking libobasis4.1-en-us-calc (from libobasis4.1-en-us-calc_4.1.4.2-2_i386.deb) ...
Selecting previously unselected package libobasis4.1-en-us-math.
Unpacking libobasis4.1-en-us-math (from libobasis4.1-en-us-math_4.1.4.2-2_i386.deb) ...
Selecting previously unselected package libobasis4.1-en-us-res.
Unpacking libobasis4.1-en-us-res (from libobasis4.1-en-us-res_4.1.4.2-2_i386.deb) ...
Selecting previously unselected package libobasis4.1-en-us-writer.
Unpacking libobasis4.1-en-us-writer (from libobasis4.1-en-us-writer_4.1.4.2-2_i386.deb)
Selecting previously unselected package libobasis4.1-extension-beanshell-script-provider.
Unpacking libobasis4.1-extension-beanshell-script-provider (from libobasis4.1-extension-
beanshell-script-provider_4.1.4.2-2_i386.deb) ...
Selecting previously unselected package libobasis4.1-extension-javascript-script-
provider.
Unpacking libobasis4.1-extension-javascript-script-provider (from libobasis4.1-extension-
javascript-script-provider_4.1.4.2-2_i386.deb) ...
Selecting previously unselected package libobasis4.1-extension-mediawiki-publisher.
Unpacking libobasis4.1-extension-mediawiki-publisher (from libobasis4.1-extension-
mediawiki-publisher_4.1.4.2-2_i386.deb) ...
Selecting previously unselected package libobasis4.1-extension-nlpsolver.
Unpacking libobasis4.1-extension-nlpsolver (from libobasis4.1-extension-
nlpsolver_4.1.4.2-2_i386.deb) ...
Selecting previously unselected package libobasis4.1-extension-pdf-import.
Unpacking libobasis4.1-extension-pdf-import (from libobasis4.1-extension-
pdf-import_4.1.4.2-2_i386.deb) ...
Selecting previously unselected package libobasis4.1-extension-presentation-minimizer.
Unpacking libobasis4.1-extension-presentation-minimizer (from libobasis4.1-extension-
presentation-minimizer_4.1.4.2-2_i386.deb) ...
Selecting previously unselected package libobasis4.1-extension-report-builder.
Unpacking libobasis4.1-extension-report-builder (from libobasis4.1-extension-report-
builder_4.1.4.2-2_i386.deb) ...
Selecting previously unselected package libobasis4.1-gnome-integration.
Unpacking libobasis4.1-gnome-integration (from libobasis4.1-gnome-
integration_4.1.4.2-2_i386.deb) ...
Selecting previously unselected package libobasis4.1-graphicfilter.
Unpacking libobasis4.1-graphicfilter (from libobasis4.1-
graphicfilter_4.1.4.2-2_i386.deb) ...
Selecting previously unselected package libobasis4.1-images.
Unpacking libobasis4.1-images (from libobasis4.1-images_4.1.4.2-2_i386.deb) ...
Selecting previously unselected package libobasis4.1-impress.
Unpacking libobasis4.1-impress (from libobasis4.1-impress_4.1.4.2-2_i386.deb) ...
Selecting previously unselected package libobasis4.1-kde-integration.
Unpacking libobasis4.1-kde-integration (from libobasis4.1-
kde-integration_4.1.4.2-2_i386.deb) ...
Selecting previously unselected package libobasis4.1-librelogo.
Unpacking libobasis4.1-librelogo (from libobasis4.1-librelogo_4.1.4.2-2_i386.deb) ...
Selecting previously unselected package libobasis4.1-math.
Unpacking libobasis4.1-math (from libobasis4.1-math_4.1.4.2-2_i386.deb) ...
Selecting previously unselected package libobasis4.1-ogltrans.
Unpacking libobasis4.1-ogltrans (from libobasis4.1-ogltrans_4.1.4.2-2_i386.deb) ...
Selecting previously unselected package libobasis4.1-onlineupdate.
Unpacking libobasis4.1-onlineupdate (from libobasis4.1-onlineupdate_4.1.4.2-2_i386.deb)
Selecting previously unselected package libobasis4.1-ooofonts.
Unpacking libobasis4.1-ooofonts (from libobasis4.1-ooofonts_4.1.4.2-2_i386.deb) ...
Selecting previously unselected package libobasis4.1-ooolinguistic.
Unpacking libobasis4.1-ooolinguistic (from libobasis4.1-
ooolinguistic_4.1.4.2-2_i386.deb) ...
Selecting previously unselected package libobasis4.1-postgresql-sdbc.
Unpacking libobasis4.1-postgresql-sdbc (from libobasis4.1-postgresql-
sdbc_4.1.4.2-2_i386.deb) ...
Selecting previously unselected package libobasis4.1-python-script-provider.
Unpacking libobasis4.1-python-script-provider (from libobasis4.1-python-script-
Selecting previously unselected package libobasis4.1-pyuno.
Unpacking libobasis4.1-pyuno (from libobasis4.1-pyuno_4.1.4.2-2_i386.deb) ...
Selecting previously unselected package libobasis4.1-writer.
Unpacking libobasis4.1-writer (from libobasis4.1-writer_4.1.4.2-2_i386.deb) ...
Selecting previously unselected package libobasis4.1-xsltfilter.
Unpacking libobasis4.1-xsltfilter (from libobasis4.1-xsltfilter_4.1.4.2-2_i386.deb) ...
Selecting previously unselected package libreoffice4.1.
Unpacking libreoffice4.1 (from libreoffice4.1_4.1.4.2-2_i386.deb) ...
Selecting previously unselected package libreoffice4.1-base.
Unpacking libreoffice4.1-base (from libreoffice4.1-base_4.1.4.2-2_i386.deb) ...
Selecting previously unselected package libreoffice4.1-calc.
Unpacking libreoffice4.1-calc (from libreoffice4.1-calc_4.1.4.2-2_i386.deb) ...
Selecting previously unselected package libreoffice4.1-debian-menus.
Unpacking libreoffice4.1-debian-menus (from libreoffice4.1-debian-menus_4.1.4-2_all.deb)
Selecting previously unselected package libreoffice4.1-dict-en.
Unpacking libreoffice4.1-dict-en (from libreoffice4.1-dict-en_4.1.4.2-2_i386.deb) ...
Selecting previously unselected package libreoffice4.1-dict-es.
Unpacking libreoffice4.1-dict-es (from libreoffice4.1-dict-es_4.1.4.2-2_i386.deb) ...
Selecting previously unselected package libreoffice4.1-dict-fr.
Unpacking libreoffice4.1-dict-fr (from libreoffice4.1-dict-fr_4.1.4.2-2_i386.deb) ...
Selecting previously unselected package libreoffice4.1-draw.
Unpacking libreoffice4.1-draw (from libreoffice4.1-draw_4.1.4.2-2_i386.deb) ...
Selecting previously unselected package libreoffice4.1-en-us.
Unpacking libreoffice4.1-en-us (from libreoffice4.1-en-us_4.1.4.2-2_i386.deb) ...
Selecting previously unselected package libreoffice4.1-impress.
Unpacking libreoffice4.1-impress (from libreoffice4.1-impress_4.1.4.2-2_i386.deb) ...
Selecting previously unselected package libreoffice4.1-math.
Unpacking libreoffice4.1-math (from libreoffice4.1-math_4.1.4.2-2_i386.deb) ...
Selecting previously unselected package libreoffice4.1-ure.
Unpacking libreoffice4.1-ure (from libreoffice4.1-ure_4.1.4.2-2_i386.deb) ...
Selecting previously unselected package libreoffice4.1-writer.
Unpacking libreoffice4.1-writer (from libreoffice4.1-writer_4.1.4.2-2_i386.deb) ...
Setting up libreoffice4.1-debian-menus (4.1.4-2) ...
/usr/bin/gtk-update-icon-cache
gtk-update-icon-cache: Cache file created successfully.
Setting up libreoffice4.1-ure (4.1.4.2-2) ...
Setting up libobasis4.1-core01 (4.1.4.2-2) ...
Setting up libobasis4.1-core02 (4.1.4.2-2) ...
Setting up libobasis4.1-core03 (4.1.4.2-2) ...
Setting up libobasis4.1-core04 (4.1.4.2-2) ...
Setting up libobasis4.1-core05 (4.1.4.2-2) ...
Setting up libobasis4.1-core06 (4.1.4.2-2) ...
Setting up libobasis4.1-core07 (4.1.4.2-2) ...
Setting up libobasis4.1-draw (4.1.4.2-2) ...
Setting up libobasis4.1-en-us (4.1.4.2-2) ...
Setting up libobasis4.1-en-us-base (4.1.4.2-2) ...
Setting up libobasis4.1-en-us-calc (4.1.4.2-2) ...
Setting up libobasis4.1-en-us-math (4.1.4.2-2) ...
Setting up libobasis4.1-en-us-res (4.1.4.2-2) ...
Setting up libobasis4.1-en-us-writer (4.1.4.2-2) ...
Setting up libobasis4.1-extension-beanshell-script-provider (4.1.4.2-2) ...
Setting up libobasis4.1-extension-javascript-script-provider (4.1.4.2-2) ...
Setting up libobasis4.1-extension-mediawiki-publisher (4.1.4.2-2) ...
Setting up libobasis4.1-extension-nlpsolver (4.1.4.2-2) ...
Setting up libobasis4.1-extension-pdf-import (4.1.4.2-2) ...
Setting up libobasis4.1-extension-presentation-minimizer (4.1.4.2-2) ...
Setting up libobasis4.1-extension-report-builder (4.1.4.2-2) ...
Setting up libobasis4.1-gnome-integration (4.1.4.2-2) ...
Setting up libobasis4.1-graphicfilter (4.1.4.2-2) ...
Setting up libobasis4.1-images (4.1.4.2-2) ...
Setting up libobasis4.1-impress (4.1.4.2-2) ...
Setting up libobasis4.1-kde-integration (4.1.4.2-2) ...
Setting up libobasis4.1-math (4.1.4.2-2) ...
Setting up libobasis4.1-ogltrans (4.1.4.2-2) ...
Setting up libobasis4.1-onlineupdate (4.1.4.2-2) ...
Setting up libobasis4.1-ooofonts (4.1.4.2-2) ...
Setting up libobasis4.1-ooolinguistic (4.1.4.2-2) ...
Setting up libobasis4.1-python-script-provider (4.1.4.2-2) ...
Setting up libobasis4.1-pyuno (4.1.4.2-2) ...
Setting up libobasis4.1-writer (4.1.4.2-2) ...
Setting up libobasis4.1-xsltfilter (4.1.4.2-2) ...
Setting up libreoffice4.1 (4.1.4.2-2) ...
Setting up libreoffice4.1-dict-en (4.1.4.2-2) ...
Setting up libreoffice4.1-dict-es (4.1.4.2-2) ...
Setting up libreoffice4.1-dict-fr (4.1.4.2-2) ...
Setting up libreoffice4.1-draw (4.1.4.2-2) ...
Setting up libreoffice4.1-en-us (4.1.4.2-2) ...
Setting up libreoffice4.1-impress (4.1.4.2-2) ...
Setting up libreoffice4.1-math (4.1.4.2-2) ...
Setting up libreoffice4.1-writer (4.1.4.2-2) ...
Setting up libobasis4.1-base (4.1.4.2-2) ...
Setting up libobasis4.1-calc (4.1.4.2-2) ...
Setting up libobasis4.1-librelogo (4.1.4.2-2) ...
Setting up libobasis4.1-postgresql-sdbc (4.1.4.2-2) ...
Setting up libreoffice4.1-base (4.1.4.2-2) ...
Setting up libreoffice4.1-calc (4.1.4.2-2) ...
Processing triggers for gnome-menus ...
Processing triggers for desktop-file-utils ...
Processing triggers for bamfdaemon ...
Rebuilding /usr/share/applications/bamf-2.index...
Processing triggers for mime-support ...
Processing triggers for shared-mime-info ...
Processing triggers for gnome-icon-theme ...
Processing triggers for hicolor-icon-theme ...
