Hello
I did a clean install (all previous file/data deleted) on my linux mint laptop. Upgraded to linux mint 22. With LO 24.2 as part of install. Now I can’t install the apso extension. Any ideas?
Regards
Zafar
    Hello
Regards
Zafar
And how is this manifested?
? Error-messages ?
Try to run with a new User-config:
soffice -env:UserInstallation=file:///home/zafar/test  --calc
        problems. i am going to remove LO and maybe install LO flatpak
removal of default LO and replacing with flatpak version solved my problem
… because flatpak use another path to userconfig.
and now you have a new problem if you want to configure the Editor (like geany …) from the flatpak -Apso !!
Personally I would avoid flatpak, but on Raspberry-hardware the last available native Package is »7.4.7.2«!
Version »24.8.… « is only available from flatpak
Sincr this is basically a new laptop I can afford to “mess around”. The default LO installation for linux mint 22 did not allow me to add apso.
